Bigger Tire concerns
Old Feb 25, 2008 | 11:04 PM
Dodge4x4810's Avatar
Dodge4x4810
Default Bigger Tire concerns
I have an '05 Daytona, i have the factory body kit on it and when it comes time for new tires i wanted to either stay with the stock 33s and just go wider to 305s...or maybe go a little bigger than 33. I think it will look fine with 33s and just going wider to 305, but i think it might look weird, if i went to say 34s because of the body kit. I was wondering if anyone had any pictures of a Daytona with larger than stock tires.
Thanks
Old Feb 26, 2008 | 12:16 AM
CRMRAM's Avatar
CRMRAM
Default RE: Bigger Tire concerns
When going with the 33's were you gonna keep the stock 20's?
What are your plans with the truck? lift or drop?
If you lift it,I would suggest romve the ground effects kit.I just wouldn't look right.
Old Feb 26, 2008 | 02:40 AM
Rot Weiss Essen's Avatar
Rot Weiss Essen
Why wouldn't it look ok with a leveling kit with the ground effects on? I have the same truck and am planning on doing the same thing with the 2.5" level kit and I am sure it will look fine. Just because it has a little front skirt and small side skirts doesn't mean you can't lift it or level it! I will post a pic when I get it done for you to see what I am running. And 305's don't look that big on the stock size wheels, unlessyour newwheels have more positive offset than the stock ones the 305's don't look that much bigger, but they are a step in the right direction.
Old Feb 26, 2008 | 07:36 AM
John  M's Avatar
John M
305/50/20 will make you quicker because they're "only" 32 inches, or an inch shorter than stock. That translates to a half inch less ground clearance and a nice kick in the pants from the effective gearing change.
Old Feb 26, 2008 | 09:41 AM
Timmerduder's Avatar
Timmerduder
her is what 315's look like with the leveling kit and no body lift.
Old Feb 26, 2008 | 12:29 PM
Dodge4x4810
Aren't 305s about 32.8"? I don't wanna go smaller, i either want to go a little taller or stay the stock size and just go wider. It's just that i have seen other trucks with skirts on it lifted with bigger tires and i just thought they looked a little odd, i haven't seen a daytona with bigger tires though. That is why i am concerned with bigger tires.
Old Feb 26, 2008 | 01:53 PM
Timmerduder
Check out this site....
http://www.miata.net/garage/tirecalc.html
It will tell you exactly
Old Feb 26, 2008 | 01:58 PM
CRMRAM's Avatar
CRMRAM
With a leveling kit it should look OK.I thought you were gonna go with an all out lift.
Old Feb 26, 2008 | 02:05 PM
oefootball_70's Avatar
oefootball_70
ORIGINAL: Timmerduder
Thats awesome, that link needs to be a sticky on the top on the section.
Old Feb 26, 2008 | 02:15 PM
Timmerduder
yeah, I got it from another post..... it works awesome
