Towing capicity
Old Feb 26, 2008 | 03:22 PM
Starko's Avatar
Starko
Default Towing capicity
What is the max weight a 2005 2500 diesel 4x4 can pull? I've read 13K is the max can I safely go higher?
Old Feb 26, 2008 | 05:25 PM
JD1500's Avatar
JD1500
Default RE: Towing capicity
read that little book in the glove box called the "manual"
yes, you can town more than 13k
Old Feb 26, 2008 | 05:47 PM
RamItOne's Avatar
RamItOne
ORIGINAL: JD1500
"manual" is that a spanish first name? ive never heard of something like that for a vehicle.
kinda scary thinking he's gonna tow 13k lbs, hope im not in front of him.
youre trailer duz have brakes right?????????? (lights dont count)
Old Feb 26, 2008 | 06:15 PM
phlytyer's Avatar
phlytyer
You can double check at http://www.dodge.com/towing. Do your search by Vehicle, Model,Body Style/drive train, Bed length, Engine/Transmission.
Example: 2006 dodge ram pickup 2500 2500 SLT, QUAD CAB, 4WD, 6.25 Ft Bed, 4-Speed Automatic Transmission, 5.9-Liter HO Cummins Turbo Diesel Engine: 13,000# (more information comes with it, but this was just an example).
Old Feb 26, 2008 | 06:51 PM
Hemichief's Avatar
Hemichief
Man
Towing over 13k on a 3/4 ton truck... That is a lot. Possibly not an issue for the engine but I would be concerned on that pull. The weight is alot to stop even with trailer brakes and a heavy duty truck.
Old Feb 26, 2008 | 07:40 PM
RamItOne's Avatar
RamItOne
I'm guessing its not a dually either? How often are you gonna be trailering this? Do you have abs? If youre gonna be doing this a lot you may want to look into better brakes, at least get the fronts done since that's where the bulk of your stopping power is. And seriously youll need a good trailer brake. Are there gonna be declines, you may want to get a good exaust brake.
Old Feb 26, 2008 | 08:33 PM
JD1500's Avatar
JD1500
my bad, i read 3500, Yeah, 13k is a stretch for a 2500 srw
