Power Steering Fluid Low
Old Feb 26, 2008 | 06:59 PM
jstmahoney's Avatar
jstmahoney
Default Power Steering Fluid Low
I noticed about two weeks ago that my power steering was low so i filled it up. I noticed yesterday it is low again. Does/has anyone had this problem with the Hemi engene? How do I fix it? My dad noticed it was leaking a little, not much at all just a drip every once in a while.
___________________
2003 Dodge Ram 1500 SLT 4x4 Quad Cab
YEAH it's got a HEMI!
Old Feb 26, 2008 | 07:19 PM
MikeHTally's Avatar
MikeHTally
Default RE: Power Steering Fluid Low
That's what it is, most likely. The connections to the rack are known to leak a bit. Look for some oil trails on the chassis or motor. I noticed as I changed the engine oil recently there is a bit of fluid on some connections. Guess it's time for some hose clamps.
Old Feb 26, 2008 | 07:52 PM
troypolla's Avatar
troypolla
I have the 2wd version of the same truck with the 4.7 and my powersteering does whine a little. I guess its a good idea to check it out.
Old Feb 26, 2008 | 08:31 PM
Mayfairisafunnymfer's Avatar
Mayfairisafunnymfer
So aren't the fittings on the rack high pressure fittings? Is it as easy as tightening them? I'm pretty certain that is where mine is leaking from.
