K&N 77 CAI Rattle
Old Feb 26, 2008 | 11:11 PM
johnsaballer's Avatar
johnsaballer
Default K&N 77 CAI Rattle
here's the situation, got a 2004 5.7L Hemi, put a K&N 77 series on it, box is on tight, IAT is in tight, pretty much in there as tight as possible. When the engine is cool everything is great sounds like it should. When the engine is warmed up there is a rattle. The rattle only happens when the truck is driving. it does not happen when it's parked and i rev it. I found another forum that had a similar issue but on a Mini Cooper and said that replacing the exhaust fixed it. It so happens I am also replacing the exhaust in the next week or so, but would rather have the rattle squared away prior to that.
Any Thoughts?
John
will post pictures tomorrow.
Old Feb 26, 2008 | 11:19 PM
HammerZ71's Avatar
HammerZ71
Default RE: K&N 77 CAI Rattle
Are sure that it's a rattle you are hearing or the EGR valve which is amplified like a jillion times by the metal tube that the 77 uses?
Old Feb 27, 2008 | 01:36 AM
Bigbody's Avatar
Bigbody
hey hey i have the same thing with mine it happens at around 2000 to 2500 rpm i brought it in to the dealer they told me i was hearing the throttle body becauseof the intake. i tried the same thing put it in neutral and reved it and nothingso maybe this could be the same thing, and i'm glad to see that someone else is hearing this other than me
Old Feb 27, 2008 | 08:59 AM
johnsaballer
I'm going to check and see if it's the EGR valve, but I don't get why it would only happen when hot, and in midrange RPM. A buddy of mine was saying he thought it could be, because it's sucking in more air that it's actually putting out. I'm thinking of just getting fire proof seals and testing them in different locations.
Old Feb 27, 2008 | 10:43 AM
SWOS Chief's Avatar
SWOS Chief
Ok, OK, OK, so watcha do is open the hood, have someone lean over the engine and close the hood as far as possible on them so you can see the drive five miles while varying the range of RPM's from 1500-6000. Let them tell you, if they are still alive whether the sound was coming from your intake or not
Old Feb 27, 2008 | 11:55 AM
johnsaballer
trust me i though about it SWOS, if i had a mile straight i might consider putting one of my less important friends on the line....kidding. it's just odd, i wonder if a plastic intake would do the same?
