Gear oil weight
Old Feb 27, 2008 | 07:26 AM
Canadian Ram's Avatar
Canadian Ram
Default Gear oil weight
I have a 04 Ram 1500 QC 4x4 5.7. I'm going to be changing diff, t-case, and tranny fluids and was wondering what type and weight of oilI should be using. Should I go with synthetic or dino? I do tow a trailer, though not often.
Any suggestions?
Old Feb 27, 2008 | 09:53 AM
tnt1036's Avatar
tnt1036
Default RE: Gear oil weight
http://www.geocities.com/dak2nv/main.html
http://www.60ateight.com/DodgeRam/
Attached sites will help you out if needed.
75W-90 for front and 75W-140 for rear, if you have a limited slip diff in the rear make sure and add a limited slip differential addative. Also if you go an auto parts store you might be able to get a diff gasket so you don't have to make your own. Change the filters in the trans while you are changing the fluid. I just saw on TRUCKS the other day that there is a kit that you can install a drain plug in your trans pan. This might be something to consider, I think I will do it next time so I can aviod the big mess. I would just be worried that I may screw it up and have to replace it.
I put mobil 1 in when I changed everything that you are going to be changing.
Good luck and doing it yourself is going to save you a ton$$$.
Old Feb 27, 2008 | 10:30 AM
Canadian Ram
Thanks for the advice. Thats what I needed to know
RamItOne's Avatar
RamItOne
I use amsoil 75w140 severe gear for the rear diff.
Old Feb 27, 2008 | 10:45 AM
tnt1036's Avatar
tnt1036
75W-140 for the rear. Sorry about that I wasn't paying attention.
Old Feb 27, 2008 | 11:10 AM
RamItOne's Avatar
RamItOne
just edit your orig post an none will be the wiser
Old Feb 27, 2008 | 11:53 AM
tnt1036's Avatar
tnt1036
ORIGINAL: RamItOne
Done, and I got ahold of Canadian Ram by PM. I had better give my messages a once over before I post them in the future.
Old Feb 27, 2008 | 12:02 PM
RamItOne's Avatar
RamItOne
when you get F'd is when someone quotes your post and then you cant do a damn thing about it.
