TRANS PROBLEMS
Old Feb 27, 2008 | 08:12 AM
cweb02's Avatar
cweb02
Default TRANS PROBLEMS
Can anyone help me!!!!!!!
I got a 2007 1500 5.7 hemi quad cab short bed and i think my trans slippin. Ill put it into gear and its like it will go to neutral only when i put it in reverese.
ANY HELP
Old Feb 28, 2008 | 04:38 AM
GunshotHemi's Avatar
GunshotHemi
Default RE: TRANS PROBLEMS
Quick Answer to your Tranny problem...Take it to the Dealer and have them "re flash" the Tranny ( I think that's the correct term). I had the exact same problem--it would slip into nuetral from reverse, just as you started backing up. The dealer knew right away what the problem was, even before I was done explaining it. No problems since they reset it. 2007 Quad w/Hemi 2WD
Old Feb 28, 2008 | 12:33 PM
cweb02's Avatar
cweb02
so you had the same problem. How long did it take it correct it and all. and in the long run does it do anything to the truck.
