my motor blew !!!!!!!!!!!!!help!
Old Feb 27, 2008 | 10:27 PM
killerbud420's Avatar
killerbud420
Default RE: my motor blew !!!!!!!!!!!!!help!
no i love the pacesetters Ltsthe only thing is if u get black there onley black for about 15mins or so.but about the truck its an 045.7with40,000 miles on it.if my camra well take a pic where the big *** gaping hole thats in my motor i put them on here so yall can see for your self
Old Feb 27, 2008 | 10:44 PM
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
REMOVE the bullydog settings from your truck and put the stock settings back before you take it to the dealer for a warranty issue. Whether they cover it via a warranty or not depends on the warranty your truck has. To the best of my knowledge headers is not going to negate your warranty.
Old Feb 27, 2008 | 11:17 PM
turbot_bird's Avatar
turbot_bird
They will try to use it as an excuse but dont let them. They tried blaming my tires for the noise my exhaust manifold was making when it broke 4 of the bolts.
Old Feb 27, 2008 | 11:28 PM
muscleman320's Avatar
muscleman320
definitely take off the setting, i believe if you look in the manual most rams (at least mine) say that external aftermarket parts will not void the warranty, as long as its only added to their parts. This means pretty much everything goes. Dodge sucks to deal with, i've had to several times here with my truck constantly messing up, best shot is to find a motor online (might as well get a kick *** crate) and do a swap. i doubt dodge wil be much help and they run the $$$$$ up the wall on everything
Old Feb 28, 2008 | 01:02 AM
killerbud420
there's a ****ty pic in my gallery if yall wanted to check it out
Old Feb 28, 2008 | 01:12 AM
mmstar23's Avatar
mmstar23
holy sh*t! saw the pic in your gallery, you gotta take some better and more pics.but damn...i think i would have cried. i wouldnt even know what to do
Old Feb 28, 2008 | 01:16 AM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
How did you blow your engine? Did you raise the rev limiter too high with your programmer?
Old Feb 28, 2008 | 02:10 AM
killerbud420
the rev limter was at 6100rpms it's been runnin good to but i went from 1st to 2nd then boooom!!! smoke all over the place oil an water pourin out the holeman if i didin have bad luck i wouldin have no luck at all[sm=smiley21.gif]
Old Feb 28, 2008 | 04:26 AM
derricksmash's Avatar
derricksmash
V6 Ram Moderator
that blows ***.
that hole in your block (if i think it's what it is) is supposed to do what it did. piston froze up, and instead of letting compression explode through your engine and ****, it blows out a cap in the block.
[/img]http://www.carsask.com/media/Coolant%20Drain%20and%20Refill/block%20drain.JPG[/img]
^^ in this photo, you see that silver/gray plug above the block drain? is the hole that blew out...like a gaping hole? or is a perfect circle?
Old Feb 28, 2008 | 10:01 AM
2005cobrakiller's Avatar
2005cobrakiller
truely blows man literally...and its a rcsb like man...hurts me deeply good luck...if i were you take the time and money and throw that 392 hemi in their thats what i would do
