Halo Headlights
Old Feb 29, 2008 | 01:23 PM
Az2500Cummins08's Avatar
Az2500Cummins08
Default Halo Headlights
I have a set of Halo LED headlights I need to install on my truck, but there are so many damn wires on them, I don't know where they go. The directions that came with them are photocopies and cant read any text or see and pictures, so I am operating blind here. Any help please?
Old Feb 29, 2008 | 03:59 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: Halo Headlights
Moved to the 3rd Gen Ram section.
Old Feb 29, 2008 | 04:16 PM
RamItOne's Avatar
RamItOne
mmstar just installed some, they look bad ***.
Old Feb 29, 2008 | 09:03 PM
RaiderJay6's Avatar
RaiderJay6
You should have seperate wires for the LEDs and halos. You can hook them up to what ever you want them to come on with. On my 02 I had them all connected to the parking lights. Some people hook up the halos to the parking lights and the LEDs to the turn signals. White is for the power and black is for the ground.
Old Feb 29, 2008 | 09:08 PM
TANKZ400's Avatar
TANKZ400
Yeah what he said.
Old Feb 29, 2008 | 09:14 PM
RaiderJay6's Avatar
RaiderJay6
Thanks Tankz!
Old Feb 29, 2008 | 10:45 PM
mmstar23's Avatar
mmstar23
alright its rather simple. looks hard but theyre really simple.
from the halos and leds get your 4 ground and your 4 positive.
the positive are red and white and your ground are the 4 black wires.
wire each of them together, wire the 4 ground together, and wire the positive together, just twist them together.
now you have 2 sets of wires that are there. 1 negative and 1 positive.
wire the 4 positives to a quick connect.
now wire the 4 negative to a quick connect.
splice into your parking light. NOT THE TURN SIGNAL. IF YOU DO THE HALOS AND LEDS WILL BLINK WITH YOUR TURN SIGNAL.
so splice into the parking lightt wire place a quick connect on the spliced wire ALSO GET YOUR OWN WIRE THATGOES FROM YOUR THE PARKING LIGHT WIRE BACK INTO IT SO THAT YOU DONT BY PASS IT.
from your new wire you put it, connect it with a crimp to the other end of your wire. so now you should have a quick connect coming from your truck that will plug into the quick connect you made from the headlight and also a wire that comes from your quick connect from the truck to the other end so that your parking light works as well.
if you have anymore questions let me know. im gonna try and draw up a diagram on paint for you.
i also checked to see which of the wires from the parking light were the blinker, parking and ground with a voltage tester.
Old Feb 29, 2008 | 11:00 PM
mmstar23's Avatar
mmstar23
how do i add an attatchment?
Old Feb 29, 2008 | 11:10 PM
mmstar23's Avatar
mmstar23
here ya go
Old Feb 29, 2008 | 11:32 PM
RamItOne's Avatar
RamItOne
ORIGINAL: RaiderJay6
White power?? lol
nice drawing MMstar, i keep looking at them on ebay, cant decide, still think a set of KCs would be a better investment for now.
what watt and candle power are your PIAA's
