Actual 1/4 mile time slips!
Old Mar 3, 2008 | 12:05 AM
John  M's Avatar
John M
Default Actual 1/4 mile time slips!
Ok, so it's not overly impressive but here it is: 15.96 @ 85
Seems kind of slow but for a 6000lb truck (5995 according to the track's scale, including my 290 lbs, 3/4 tank of gas) with $500 in mods I guess it's ok.
First slip:
60ft: 2.38
1/8: 10.21
mph: 64.0
1/4: 16.14 @ 83.24 mph
Backed that up with a nearly identical run vs. a stock Chevy Silverado SS, which totally killed me with a 15.2 @ 88.7. Theoretically they make the same power and weigh a little more than I do but apparently the numbers miss something.
Since my truck is a 2003 and the Superchips can't change the shift points, I decided to then shift it myself. I let it do the 1-2 on its own and then shifted 2-3 myself right at 6k rpm.
60ft: 2.39
1/8: 10.32
mph: 68.35
1/4: 16.04 @ 85.65
Hey, that made a big difference! Why not try manually shifting the 1-2 as well?
60ft: 2.33
1/8: 10.24
mph: 68.45
1/4:15.96 @ 85.02
That's the best it had so I called it quits for the day. I have 56k miles and it's on stock plugs & wires so they'll be done soon. Also, over the past 10 years this track has consistently been slower than my local 1/8 mile results, by several tenths, so it can always vary a little either way.
Future mods include exhaust and efans, and one day a cam if I can find an installer in the southeastern US.
Old Mar 3, 2008 | 12:11 AM
HighDuke1911's Avatar
HighDuke1911
Default RE: Actual 1/4 mile time slips!
kool! the ss is smaller though. you have a quad cab. hes extended or whatever they call it.
Old Mar 3, 2008 | 12:18 AM
AIR RAM's Avatar
AIR RAM
Not bad for a 4x4 full size truck....
SPEED SAFE, AIR RAM
Old Mar 3, 2008 | 12:24 AM
RamItOne's Avatar
RamItOne
did you deep stage it? every inch counts... thats what she said!!!!
what was your reaction time?
Old Mar 3, 2008 | 12:31 AM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Not bad for a QC 4x4 with a heavy driver. Get a stall, some good tires and practice your launches.....that 60' will drop way down.
Old Mar 3, 2008 | 12:41 AM
RAM0447's Avatar
RAM0447
Not bad at all.....I'd hate to see what the 4.7 does.....im guessing mid 17's lol
Old Mar 3, 2008 | 09:13 AM
derricksmash's Avatar
derricksmash
V6 Ram Moderator
i bet you my 3.7 would run a mid-30 or so...maybe a 36.7?
Old Mar 3, 2008 | 11:22 AM
AIR RAM's Avatar
AIR RAM
ORIGINAL: RAM0447
Check out my sig for that answer.... of course its not stock but it is Naturally aspirated.
SPEED SAFE, AIR RAM
