What is needed at 30k miles
Old Mar 4, 2008 | 08:12 PM
RamItOne's Avatar
RamItOne
Default What is needed at 30k miles
What is typically needed to be done at 30k miles?
Thanks
Old Mar 4, 2008 | 08:26 PM
ray97's Avatar
ray97
Default RE: What is needed at 30k miles
Should be in your book, but I believe it is a tune-up, trans service, rear end, radiator flush, brake fluid, and maybe a couple other things that the dealer through at me when I did it. I did not mind at the time because I had just bought the truck.
Old Mar 5, 2008 | 07:26 PM
allpro1993's Avatar
allpro1993
30,000 im sure its the engine coolant better off doin it yourself since there only gonna drain and fill but the trans is due at 50,000 go with the t-tech service as this pushes out all the old fluid like a flush and theres no need to change the filter or drop the pan like the old days. once u start poppin gaskets it always a prob. most plugs today are good 4 50,000 or better dep. on make
Old Mar 5, 2008 | 10:20 PM
allpro1993's Avatar
allpro1993
um thats the end? lets have a tune up forum is there a dodge club theres a bike club im ridin a vrod when im pissin off chevys
Old Mar 6, 2008 | 12:23 AM
JD1500's Avatar
JD1500
I plan for this, cause my mileage just took a dump..(32k)
Check Tranny
Front/Rear Diff
Clean throttle body
Pull a few plugs, see if ok, or need change.
Filter.
Drain/replace washer fluid.
Rotate Tires (well, that is just cause they are due)
Old Mar 6, 2008 | 07:23 AM
VA4MEDS's Avatar
VA4MEDS
Call the dealer to find out what they do, then do it yourself and save money.
Speed Safely,
AL
