Another tire Question-Sorry!
Old Mar 5, 2008 | 07:17 PM
rockinjwolf's Avatar
rockinjwolf
Default Another tire Question-Sorry!
I own an 05 2500 4x4, replacing stock tires. It now has 265's on steel/ chrome wheels-17". I found a set of stock alum. 17's and want to know if I can upgrade to 285's without any mods. - Thanks
Old Mar 5, 2008 | 07:27 PM
allpro1993's Avatar
allpro1993
Default RE: Another tire Question-Sorry!
as long as weght ratio is as good or better
Old Mar 5, 2008 | 09:29 PM
Pirata's Avatar
Pirata
From: 2nd star to the right, then straight on until morning
Metric tire measurements don't mean squat without all 3 measurements, IE: 285/70R17. The first number is the tread width. The second number is a percentage if the treadwidth on the side wall. The third number is the rim size. In this case the tire tread width is 285mm, the sidewall is 70% of thetread width (199.5mm) and the rim is 17" making this example 33" x 11.2" on a 17" rim. If this is the size of tire you are looking to put on it should fit a stock suspension setup.
