ignition coil failure
my bfs mom has an 04 hemi ram, they are comin back from tenns were it was snowing, she is gettin 2 trouble codes p2308 and p2317 and we looked it up it is the 3rd and 6th secondary ignition coil failure, 67k on the truck and the 6th coil is brand new was replaced in january after they came back from ga, and the volt is reading above 14.0 volts on the gluster, been that way the entire trip, up and back, so all u hemi ram guys got any suggests for him
his username is turbot-bird
Not sure...all I can say is that the hemi coils do work a lot harder then the average coil-over-plug ignition. Not only do they fire two plugs but they fire every crank revolution instead of the normal every two revolutions. The working harder combined with the cold temps could be shortening their life.
You could always put these bad boys on http://www.msdignition.com/new_products/82438.html
Have you guys checked the wiring harnesses going to the coils?
I would try just swapping that coil out with another and see what happens and visually inspect the connection to the coil real good.
