need to find vss wire 07 ram
Old Mar 13, 2008 | 12:38 AM
rcorona888's Avatar
rcorona888
Default need to find vss wire 07 ram
Does anyone know where's the vss (speed pulse generator) wire located in the 07 ram hemi have to instal a jvc kd nx-5000 nav.stereo
Old Mar 13, 2008 | 01:37 AM
Horseapples's Avatar
Horseapples
Default RE: need to find vss wire 07 ram
I dont know, sorry. Best Buy can find it for you if you have enough time, their installers have access to the"All Data" program and can pull up every wire in your truck. Hope this helps.
Old Mar 28, 2010 | 01:25 AM
davb673's Avatar
davb673
Well, I have been digging into this for a while, and there is no VSS listed for our trucks in the connector pin-outs. You can look here: https://dodgeforum.com/forum/audio-v...s-hook-up.html as a couple of us were discussing it for 08s, but the 07 wiring seems the same. 06 models do have a VSS and a pin in the PCM. There is a speed sensor in the tranny, and that is the wiring that is referred to in the link above. I think if you go to rostra.com, avic411.com or the12volt.com you may find more information.
Old Mar 29, 2010 | 08:06 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
http://www.the12volt.com/installbay/....asp~TID~95175
