Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. Let's hear about it here.
2008 Dodge Ram VSS hook up
Old Feb 23, 2009 | 08:40 AM
JRam08's Avatar
JRam08
Default 2008 Dodge Ram VSS hook up
I'm installing an Eclipse AVN5500 and was wondering if somebody could tell me where the VSS hook up is for the truck.
Thanks in advance.
Justin
I have the CH2-CRY, CAN2.
Old Feb 24, 2010 | 11:02 PM
davb673's Avatar
davb673
I do not know off-hand, but I have asked a friend of mine who works in a Dodge dealer repair section. When I hear back, I'll post here...
Old Feb 25, 2010 | 09:48 PM
WBattack's Avatar
WBattack
It is Dark Green/Brown at PCM on passenger side firewall.
Old Mar 13, 2010 | 04:52 PM
davb673's Avatar
davb673
Try looking here: http://www.dodge.com/bodybuilder/2008/dr/drmo.pdf
From what I read for my truck (07), WBattack is right. It is the dark green/brown stripe wire in the 4th connector at the PCM. Should be pin 32. I am using this wire to connect an MPGuino FE computer. I have heard sometimes the bodybuilder diagrams are a bit off or incomplete. I think I looked at the wrong wire, or had bad lighting as I THOUGHT I had the DG/brn wire. There is also a DG/orange wire at pin 33 in the same connector...
Here is a link to 12volt where they were asking the same questions about an 04. http://www.the12volt.com/installbay/...63939&get=last
You can also take a look at Rostra's cruise control pages: http://www.rostra.com/pdf/Form4428.pdf
Hope this helps.
Old Mar 17, 2010 | 01:32 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
WBattack has it correct
http://www.the12volt.com/installbay/...~114758#556188
