3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
OK, here it is if I can explain it right. When my truck is programmed with the 3815 to the 87 Tune, only other adjustment is speed limiter and tire size, I get a check engine light, the code is 420, which is a bad O2 sensor. The CEL comes on after about half a tank. I cleared the CEL and set back to stock to get ready to take to the shop. Now 2 tanks later no CEL. I have gotten the light three times when the truck is programmed. Any ideas? I want the CEL on so I can get the O2 sensor replaced under warranty.
