Tires, 33.00 x 12.50-17
Old Mar 15, 2008 | 02:35 PM
CarGuyOhio's Avatar
CarGuyOhio
Default Tires, 33.00 x 12.50-17
Anyone running this size tire without a lift or without a leveling kit?
From what I hear a 305/65/17 will run fine, which is just a little smaller. About .5" in diameter and about .5" width smaller. But if I can move to a 33x12.5x17 I have a lot more tire options.
I was going to do a lift, but in the end being able to get in the garage at home and at the airport won. Next truck.
Old Mar 15, 2008 | 03:57 PM
HammerZ71's Avatar
HammerZ71
Default RE: Tires, 33.00 x 12.50-17
I ran Mickey Thompson MTX 33x12.5x17 on mine from the time it was a month old til I put the lift on at 29k miles. No problems, clear easily, even when pushing it off-road...
Here is a pic, stock height with the 33's:
[IMG]local://upfiles/67238/B4C1ECE3B788419AAF79074170BC9C4B.jpg[/IMG]
Old Mar 15, 2008 | 03:58 PM
Redram05baby's Avatar
Redram05baby
Lance, I Don't See A Problem With That - I Was Running 325/60R18's With A Mere Crank on The Torsion Bars - Still Fit In Any Standard Garage Door Opening and Had No Rubbing Issues.
Even With My 285/75R18's I Still Have Yet To Find A Clearance Issue On Any Garage Door.
Hope That Helps.
Old Mar 15, 2008 | 08:23 PM
nickcoletti's Avatar
nickcoletti
from what i have read from people writing in with their new tires on this site..... they will fit without a problem. that is the size i plan on going this summer in pro comps!
Old Mar 15, 2008 | 10:47 PM
nremt1984's Avatar
nremt1984
285-70/17 is a proper fit you will have little issues with the speedo discoverer stt look nice with torsion bars cranked
Old Mar 15, 2008 | 11:09 PM
CarGuyOhio's Avatar
CarGuyOhio
Hell, I did not realize our stock 20" rubber is about 33" tall already, measured them today, then compared them on summitracing.com (they have nice stats on tires in terms of size).
I will be going with Firestones or the Coopers, the Coopers look better, but the cost will be the deciding factor. I am sure the Coopers are more, which I will pay more, just not a lot more.
Old Mar 16, 2008 | 03:07 AM
Rot Weiss Essen's Avatar
Rot Weiss Essen
The Cooper's are not an expensive tire, most of the all-terrains and muds out there are all more expensive than the Cooper's! Check out the price of a BFG All-Terrain or a Toyo Open Country Mud or a Micky Thompson or Dick Cepek or even a Goodyear Wrangler ATS. Even the Nitto's are more than the Cooper's, so if you do get the Cooper's you didn't spend an arm or a leg by any stretch of the imagination.
