just venting a little bit
Old Mar 15, 2008 | 08:21 PM
hemiyellow's Avatar
hemiyellow
DC Insider
Default just venting a little bit
ok well just need to vent a little bit cause i'm pretty irate right at the moment....i got some new brake calipers from a guy that works at TRW, so since it was nice today i decided to throw em on and see how they did....went through all this crap, got the new caliper on and bled the fronts (new calipers) like i've done in the past at the dealership and on my own vehicles....start the truck and pedal goes right to the floor...bleed em again and have the same results....so i bleed the rears and then the fronts again...pedal feels better but after pressing the pedal and then letting it sit for a minute, the pedal goes right to the floor...needless to say i'm pretty irritated at the moment.....never in my life, have I had problems bleeding brakes before and now i have this....ok i'm done venting now......anyone got any suggestions? i've tried the logical ones that i thought of but obviously that didn't work
Old Mar 15, 2008 | 08:29 PM
SeVeReDiStOrTiOn's Avatar
SeVeReDiStOrTiOn
Default RE: just venting a little bit
You didn't let the brake reservoir go empty when bleeding did you? If dodge is anything like chevy then if you did you'll have to bring your truck in and have the ABS module bled...but hopefully you didn't do that.
Usually if the pedal goes to the floor you havea open somewhere or a **** load of air in the lines...do you see fluid spewing out anywhere?
Old Mar 15, 2008 | 08:31 PM
SeVeReDiStOrTiOn
Also i'm sure you know this but you wanna bleed farthest from the master cylinder first and then work closer. So RR, LR, RF and LF...those are all the ideas I have right now[&o]
Old Mar 15, 2008 | 08:57 PM
JonM's Avatar
JonM
Is it possible one of the new calibers is bad? Possibly a seal or something.
Old Mar 15, 2008 | 09:30 PM
Redram05baby's Avatar
Redram05baby
As Severe Said - If You Have Any Noticeable Leaks That Would Explain That, But I Figured You'd Mentioned That.
If You Replace The Calipers You Had To Have Lost A Decent Amount Of Fluid. So I Would Expect To Have To Bleed The Calipers A Decent Amount PR - DR - PF - DF. A Couple Of Times Allowing It To Be Always Topped Off. To Me It Just Sounds Like You Have Air In The Lines...
If It Was The ABS That Had Air In it, It Wouldnt Pressurize and Would Give You ABS Light. If You Don't Have An ABS Light - I Would Once Again Do A MAJOR Bleeding Session.
Old Mar 15, 2008 | 09:49 PM
hemiyellow's Avatar
hemiyellow
DC Insider
yeah well ya know, i bled the brakes like suppose to, never let the resivoir get empty (learned my lesson once at the dealership lol)....i think tomorrow mornin i'm gonna put the stock caliper back on and see what happens with that and go from there....would go out there and do it now but if the stock caliper fixes it then it'd just make me even more mad lol
Old Mar 16, 2008 | 10:53 AM
chadmech28's Avatar
chadmech28
These calipers that you got are they performance calipers. Because the clipers that are on the truck are trw from factory. I have had a couple of ram truck that were hard to bleed out the air. maybe try a gravity bleed for awhile?
Old Mar 16, 2008 | 03:34 PM
tmodlin's Avatar
tmodlin
ORIGINAL: hemiyellow
If you only bled the fronts the first time then I would say that you didnt do it right the first time. Any time you open the brake system you should bleed all four wheels starting with the furthest from the master. How are you bleeding them too? Pumping the pedal or with a hand pump or with a pressurized bleeder on the master?
Sounds to me like you have a bunch of air in the system still.
Old Mar 16, 2008 | 04:40 PM
hemiyellow's Avatar
hemiyellow
DC Insider
yeah i threw the old caliper back on today and went through and bled the whole system twice...pedal feels better but still sounds like theres some air in the system....i dunno, i know i'm done screwin with it today cause it's just pissin me off lol....maybe tomorrow when i get home from work if it's nice outside
Old Mar 16, 2008 | 06:41 PM
HighDuke1911's Avatar
HighDuke1911
take it to work... lol.
