p0052 driving me nuts!!!
Old Mar 15, 2008 | 11:44 PM
03ramster's Avatar
03ramster
Default p0052 driving me nuts!!!
Hey guys, i'm new to posting to this forum, but i always read posts from here. well like the title says, my truck is driving me nuts. I keep getting this p0052 code and i already changed my o2 sensor like the mechanic from mobil one inspection station told me to do so. He told me to change the one on the passenger side after the catalytic converters, and so i did but it still keeps throwing the same code. He said that i might need to reset the computer but nothing changed. Please help also noticed the gas mileage has gotten worse, i have an 03 dodge ram pickup, 4.7
Old Mar 16, 2008 | 10:57 AM
chadmech28's Avatar
chadmech28
Default RE: p0052 driving me nuts!!!
This code is for a 2/1 o2 sensor heater high, The o2 sensor that he told you to change is wrong it is the upstrem o2 sensor. Replace it if you want to fix you problem.
Old Mar 16, 2008 | 12:18 PM
03ramster's Avatar
03ramster
Another question? can i use the original one in the back and put it in the front? Or are these sensors different?
Old Mar 16, 2008 | 01:52 PM
chadmech28's Avatar
chadmech28
They are probally different, Up stream and downstream or sensors don't usually work the same. But yo can call the parts department and check.
Old Mar 16, 2008 | 02:07 PM
03ramster's Avatar
03ramster
well thats the thing, at oreilly's store they sold me the universal o2 sensor and they told me it should work on both ways. the only problem is that the universal you have to splice it. I used the connectors that i got with it, but i don't know if they are going to do the job. what do you recommend, should i just go to the dealer and buy the original ones or whats the best thing to do? these universal one cost me 60 bucks.
Old Mar 16, 2008 | 05:57 PM
chadmech28's Avatar
chadmech28
You sould never splice an O2 sensor there is resistance value to think about. Go to the dealer and buy both 02 senorsand install them.
Old Mar 16, 2008 | 07:24 PM
kenihemi's Avatar
kenihemi
P0052 O2 SENSOR 2/1 HEATER CIRCUIT HIGH - possible causes;
O2 HEATER TEST
O2 SENSOR HEATER ELEMENT
(A141) FUSED ASD RELAY OUTPUT CIRCUIT
HEATER CONTROL CIRCUIT OPEN
HEATER CONTROL CIRCUIT SHORTED TO GROUND
PCM
Like Chad said, that is the front sensor. Its the one on the passenger side.
Taking the cheaper way out doesn't work most of the time. You'll wind up paying more in the end.
My suggestion is to get a new sensor for the front from the dealer and try that. If you cut the wires to splice them, then you have to be super careful to get the wires right. Solder/heat shrink, etc.
Old Oct 29, 2020 | 11:21 PM
Eric Hamilton's Avatar
Eric Hamilton
Default Universal o2
You can splice in o2 sensors wires with water proof butt connectors only don’t believe me contact ntk cannot solder connection will stop the air flow through the wiring
Old Oct 29, 2020 | 11:28 PM
Alex Medeiros's Avatar
Alex Medeiros
12 year later
Old Aug 20, 2022 | 03:39 PM
dsfab28's Avatar
dsfab28
Default air cooled wires?
Air flow through the wiring? Really?
