jacks and jack stands
Old Mar 16, 2008 | 06:53 PM
ryland's Avatar
ryland
Default jacks and jack stands
How big of a jack and jack stands is the right size for the truck? 2 ton, 3 ton? Is it ok to put the jack under the rear diff. to jack it up? Where do you jack from in the front? Thanks
Old Mar 16, 2008 | 07:02 PM
JD1500's Avatar
JD1500
Default RE: jacks and jack stands
2 or 3 ton will work. Yes you can jack up under the rear diff. Find a strong cross member in the front, or jack up one side at a time by the frame. Easiest for me in the front is to drive it up on ramps.
Old Mar 16, 2008 | 07:08 PM
kenihemi's Avatar
kenihemi
A 2 ton jack is fine for lifting one side of the truck at a time or the front and rear separately.
Yes, you can lift the rear using the diff or if you want the suspension to hang, then use the frame or hitch mounts.
The front depends what you are doing.You can use the frame crossmember or you can just raise one corner, etc.
2 ton jack stands for one half of the truck are fine.
Old Mar 17, 2008 | 03:56 PM
RamItOne's Avatar
RamItOne
i bought a floor jack that goes up 23 inches and wont lift my truck to change a tire. I'm looking at buying a farm jack, itll be good cause it can work at the beach as well.
Old Mar 17, 2008 | 04:18 PM
MikeHTally's Avatar
MikeHTally
Just don't try to lift at the diff if there is beaucoup weight in the bed.
Old Mar 17, 2008 | 04:24 PM
HighDuke1911's Avatar
HighDuke1911
ORIGINAL: MikeHTally
lol. sorry, had to laugh at the french used. hahahaha. i love it! imin french class in college. thats why i find it amusing. hahahaha.
Old Mar 17, 2008 | 04:54 PM
RamItOne's Avatar
RamItOne
I prefer ****load of weight. Pardon my French. Ha
Old Mar 17, 2008 | 05:29 PM
hemiyellow's Avatar
hemiyellow
DC Insider
i got a couple 6 ton jacks and a 6 ton floor jack lol....it was on sale at Sears for $200 for 4 jacksstands and the floor jack
Old Mar 17, 2008 | 09:47 PM
MikeHTally's Avatar
MikeHTally
I have an elderly three-ton floor jack and three-ton jack stands. I use the stands to hold his rump up while I rotate the tires. Used to support my '66 LeMans drop-top with the stands to preserve the tires.
