to those with low mpg issues....
Old Mar 22, 2008 | 10:19 PM
HammerZ71's Avatar
HammerZ71
Default RE: to those with low mpg issues....
ORIGINAL: redrum25
Don't think it will help me much. My truck is only a couple months old with 1300 or so miles.
My current average is just over 11 mpg
I clean mine religiously once a year, and by the amount of crud I get out of it, I should do it more often.
Unfortunately, redrum, 2500s (3/4 ton trucks) don't get the fuel economy of the 1500's. No MDS (don't feel bad, my 04 - 1500 doesn't have it either, and I don't want it), more weight from the frame, bigger axles (we don't even have a front axle - and believe me, I'd give up a couple MPG's for a solid front axle) are the biggest reason's.
What you have over a 1500 in frame & suspension strength, costs you fuel economy. From past input I've heard from 2500 Hemi owners, you're about right on in the mpg department. You may pick up another mpg as it continues to break in...
Old Mar 22, 2008 | 10:25 PM
ThaChad's Avatar
ThaChad
If your throttle body is getting dirty, than your air filter isn't doing it's job. Either you need to change the air filter more often (This too can increase MPG), or if you have an aftermarket cotton gause filter, than it is passing way too much dirt! Prehaps from not oiling properly, or a poor quality filter.
If dirt is getting into the TB, than its also getting into the engine, which can cause build up in the combustion chamber, scratching of the poston and cylinder walls, etc.
-ThaChad
Old Mar 22, 2008 | 10:31 PM
StevenMoffettKY's Avatar
StevenMoffettKY
I had been intending to do this for while, last day of my vacation tomorrow. Probably going to try to get this done in the morning, weather permitting.
Old Mar 22, 2008 | 10:39 PM
HammerZ71's Avatar
HammerZ71
ORIGINAL: ThaChad
-ThaChad
Sounds like good advice, but it isn't that simple. There is actually a Chrysler TSB out on the subject. All Hemi's seem to get more dirt in the TB faster than any other engine on the planet. The first I learned of this, I checked mine while the whole intake system was still factory and the truck had a little over 6,000 miles on it. The TB was already gunked up a good bit. Since the addition of my CAI you'd think it would gunk up more and faster because it's sucking more air, but that's not the case, it's about the same.
So, with your theory (which I normally would agree with) you'd have to change the air filter at 3k miles when you do the engine oil & filter. And I'm not so sure that at that, you still not have to clean the TB.
So, I'd say, yes replace that filter more often (or clean it more often than the recommended intervals if it's a cleanable one) but still check that TB out and clean it when it's gunked up, if you want optimum MPG's...
Old Mar 23, 2008 | 01:55 AM
cpukramer's Avatar
cpukramer
Is this a recurring problem on the 4.7L as well? I may have to take a peek at mine! My MPG went down to about 12 the last few months. Probably a combination of 4X4 and my new tires. I never got better than 14 though.
Old Mar 23, 2008 | 12:40 PM
ThaChad's Avatar
ThaChad
ORIGINAL: HammerZ71
That begs the question... Where's the dirt coming from? Is it dirt?
-ThaChad
Old Mar 23, 2008 | 01:24 PM
JD1500's Avatar
JD1500
It looked like carbon build up when i cleaned mine. I dont know what it actually was, but it was a blackish grey film on it.
Old Mar 23, 2008 | 04:57 PM
damram1980's Avatar
damram1980
lay off the pedal
Old Mar 23, 2008 | 05:18 PM
HankL's Avatar
HankL
egr puts black crud into the manifold and throttle body
Old Mar 23, 2008 | 05:20 PM
JD1500's Avatar
JD1500
ORIGINAL: ramman1980@gmail.com
lay off the pedal
Wow, thanks for that insight *** hat. The poor mileage was on the same roads, with the same driving style as before when i was getting 17-18. It had nothing to do with throttle, it was my dirty, sticky TB
