Limited Slip Differential Fluid?
Old Mar 25, 2008 | 01:14 AM
RamItOne's Avatar
RamItOne
Default RE: Limited Slip Differential Fluid?
MMStar
http://www.amsoil.com/storefront/svo.aspx for the rear.......
http://www.amsoil.com/storefront/svg.aspx for the front, you can even use the 110 if youd like (for 4wd trucks)
btw amsoil does sell an LSD additive but their website and mechs that i have talked to said that you dont have to add the lsd additive when you use the severe gear as it already has some in it. i havent heard any chatter at all.
Old Mar 25, 2008 | 07:05 AM
MikeHTally's Avatar
MikeHTally
C-clips were used to hold the clutch packs together when the 9 1/4" corporate LSD rearend was assembled at the factory. They sometimes fail, less often catastrophically, causing gear and housing damage. This does not apply if your truck does not have LSD. As stated, you need 75w-140 synthetic in the rear diff and 75w-90 in the front. If the truck does have LSD, you need four ounces of friction modifier for the clutch packs to do their job. These lube specs are from the shop manual on my '03, but it isn't likely to be different. To find out if your truck has LSD, look for a sticker on the glove box door and a reference to "... anti-spin ..." If there is no sticker, find a place where you can put one rear wheel on a slippery surface and one on a dry surface. Goose it. If it just spins the wheel on the slippery side, you don't have LSD. If it spins briefly and then moves out, you do have LSD.
Old Mar 25, 2008 | 09:53 AM
mmstar23's Avatar
mmstar23
i dont think i have LSD then, only 1 tire spins when ive done it before. wish both would spin..but hey, just the passenger side rear spins. in this case what fluid do i need for my differential? i was gonna go with royal purple
Old Mar 25, 2008 | 09:56 AM
NYPANAMA42's Avatar
NYPANAMA42
I guess the requirements for fluids have changed, from one year to the next. My manual indicated that it's supposed to take
75W-90GL For th front and rear. with the Limited slip diff. fluid being added to the rear only.....
how come you guys are using this 140 stuff? were you're rear differentials designed differently?
Old Mar 25, 2008 | 10:40 AM
RamItOne's Avatar
RamItOne
You must have the 10 bolt 8.25 rear end.
We have the 9.25 12 bolt
Old Mar 25, 2008 | 10:43 AM
RamItOne's Avatar
RamItOne
Mmstar LSD or anti spin is more common on 4wd. Its only like a 300 option so dont know why they dont put them in all trucks.
Old Mar 25, 2008 | 01:37 PM
HammerZ71's Avatar
HammerZ71
ORIGINAL: NYPANAMA42
i was at the dealership today and they indicated that it was $18.00 dollars a bottle.
where did you buy yours Hammer for only $4.95 a bottle?
Just checked my invoice, was charged $5.25 for 4 oz. of friction modifier when I had the gears checked and fliuds changed at 4 Wheel Parts at my 500 mile check, after having them change my gears.
I think I remember seeing it for $5.95 at Advance, though...
Old Mar 25, 2008 | 03:46 PM
mmstar23's Avatar
mmstar23
no its a 12 bolt......pretty sure its a 9.25, not POSITIVE but pretty damn sure. 3.92 gears too.....thats what its says on the axle. it has 12 bolts..i can count. the sticker says 3.92 and the sticker that says the size is ripped right where it says the size i conly only read " .25" figures the first # is gone!
Old Mar 25, 2008 | 04:05 PM
MikeHTally's Avatar
MikeHTally
From my '03 shop manual. Not sure 'bout the '02, and my '04-'06 manuals are on a different PC:
FRONT AXLE
²
C205F - Mopart Gear Lubricant 75W-90
²
9 1/4 AA - Mopart Synthetic Gear Lubricant
75W-90
REAR AXLE
²
9 1/4 - Mopart Synthetic Gear Lubricant 75W-140
²
10 1/2 AA - Mopart Synthetic Gear Lubricant
75W-90
²
11 1/2 AA - Mopart Synthetic Gear Lubricant
75W-90
NOTE: Trac-Lok
T differentials require Limited Slip
Additive in the lubricant. Trac-Riteâ„¢ differentials
DO NOT require Limited Slip Additive.
Old Mar 25, 2008 | 05:25 PM
damram1980's Avatar
damram1980
if ur gonna go through the trouble , get shiny new dif cover
