Tips when changing plugs
Old Mar 25, 2008 | 06:45 PM
HammerZ71's Avatar
HammerZ71
Default RE: Tips when changing plugs
ORIGINAL: ramman1980@gmail.com
bosch is workin good for me
I personally only used Bosch Platinums in all three of my Grand Cherokees with the 4.0 I6 and both Wranglers with the same engine. They gave great performance and 1.5-2 mpg's better than the stock plugs in every one of them. Tried them in my current Grand Cherokee Overland with the 4.7 H.O. and they perform well there too (not the same gains as in the 4.0, but no problems. But I, like many others, have had issues (unsteady idle, lower mpg's) with them in my Hemi...
Old Mar 25, 2008 | 06:52 PM
damram1980's Avatar
damram1980
i agree wit hammer, i bought the new ones bosch came out with, they are bimetel? 1/2 copper diode and 1/2 platinum like i said its workin great seems a little pepier and smoother
Old Mar 25, 2008 | 06:58 PM
Horseapples's Avatar
Horseapples
ORIGINAL: HammerZ71
Dammit Horsey, if you just had a few pics on your last couple of posts, I'd recommend they be "Stickey's"...
I will get the camera out, i still have the front end torn off of mine foe a cam swap( again) I'll snap a few pics
Old Mar 25, 2008 | 07:09 PM
HammerZ71's Avatar
HammerZ71
Horsey,
Me thinks you need to make a trip to "sunny Fla." to visit me and my neighbor down the street. You could even put my KRC 210 in while you are here. Might be a beer or two in it for ya'...
Old Mar 25, 2008 | 10:54 PM
Horseapples
I am always up for a road trip Hammer!
heres the pics I promised, ill try to get them in the right order, but I am having a hard time uploading pics.
1) egr tube
2)egr bolts
3)coil bolts
4)coil removed
5)removing plug
6)retrieve with magnet
7)install plug
Old Mar 25, 2008 | 10:59 PM
Horseapples
EGR VALVE
[IMG]local://upfiles/26683/2C54D6FEB0624199A60F72B3CC6F57EA.jpg[/IMG]
Old Mar 25, 2008 | 11:03 PM
Horseapples
That didnt work worth a crap either! screw it, Ill try again tomorrow!
Old Mar 25, 2008 | 11:27 PM
Tractor's Avatar
Tractor
I used the Bosh Platinum in our 04 2500 and loved them so much I took them out before I traded it in. It is worth it to me NOT to have to change them every 30k. I also heard the problems are with the double and quad platinums not the single regular looking plugs. Get yourself a piece of hose to fit over the ceramic to make the back ones easier to install. I actually sat in the engine comp with feet down by the PSpump to do the drivers side. You WILL need a swivel.
Old Mar 26, 2008 | 12:22 AM
Horseapples
I can change mine at the track between runs, about20 minutes, and dont use the swivel socket. Where are you guys using a swivel? which plug?
Old Mar 26, 2008 | 05:38 AM
sa1765's Avatar
sa1765
i had to use it in the rear (taken out of context, that could sound a little queer) to get around the brake booster on the driver side...and, crap, something on the passenger side, can't remember now....something with the A/C maybe
