I can't pull my codes?!?
Old Apr 4, 2008 | 01:56 AM
Sled's Avatar
Sled
Junior Member
Default I can't pull my codes?!?
Title says it all. I have searched on this BB and others.
I tried the method in this thread... https://dodgeforum.com/m_691136/tm.htm
And in this one..... http://www.allpar.com/fix/computer-codes.html
And another..... https://dodgeforum.com/m_1257738/tm.htm
But I get nothing, I do have a check engine light (steady , all the time) and I know the problem is my EGR valve (dealer pulled code and told me)
Iam just trying to figure out why I can't get the code myself?
Do I need to try a different method?
2004 Ram 1500 4x4 quad-cab Hemi
TY
Sled
Old Apr 4, 2008 | 01:57 AM
RamItOne's Avatar
RamItOne
Default RE: I can't pull my codes?!?
cant help ya, you know you can go to most any auto parts store and theyll do it for free. or buy an OBD
Old Apr 4, 2008 | 02:00 AM
Sled's Avatar
Sled
Junior Member
ORIGINAL: RamItOne
Ya I know, AAMOF ,my dealer will do it for me for free, that is how I know it is an EGR. I am just trying to figure out why I can't do it here at home, like the above threads say.
Old Apr 4, 2008 | 02:01 AM
StevenMoffettKY's Avatar
StevenMoffettKY
Have you tried pulling the negative battery cable to reset it and see if it still remains or will not let you pull it yourself?
Old Apr 4, 2008 | 02:08 AM
sa1765's Avatar
sa1765
i don't know if any of that is year specific...but it won't work on mine either. my light is on....went to o'reilly's, got the code, took the reader back inside and when i came back out i tried it just for ****s and giggles...no luck. oh well.
Old Apr 4, 2008 | 12:27 PM
Sled's Avatar
Sled
Junior Member
ORIGINAL: rcroll3
did you read the note in the DIY it says Note, early 3rd Gen Rams do not support this feature.
Ya I saw that, I was hoping it did not apply to the whole procedure, also my truck being an 04 I didn't consider it to be that "early" a gen 3, as Gen 3 starts in 02.
oh well I guess it is.
So does that mean that for 3 years or so there was no way for the customer to pull their codes? I can see why that didn't last.
Old Apr 4, 2008 | 03:38 PM
daytona1680's Avatar
daytona1680
I pulled them on my 02 ram using the key on-off-on-off-on trick...
Old Apr 4, 2008 | 03:44 PM
Sled's Avatar
Sled
Junior Member
ORIGINAL: daytona1680
Well, there you go. I thought I had seen some other threads were people had pulled them on trucks older than mine.
I wonder if anyone with an 04 PU (hemi) has been able to pull their codes?
I still wonder if I am doing something wrong?
Is it On / off? or On / ACC?, I have seen it both listed both ways?
Old Apr 4, 2008 | 03:57 PM
daytona1680
I pull them fine on the 05 hemi I have now..put the key in then go on-off-on-off-on and the gauges will light up, then where the odometer is it will flash the codes then say done, if there are no codes it will just say done
Old Apr 5, 2008 | 01:07 PM
kenihemi's Avatar
kenihemi
The key trick does not work on the 04's. Don't know why, but I know a handful of 04's that it will not work on including mine.
