Tranny Rear seal leak
Hey guys as the subject points out the rear seal on my transmission is leaking but the issue is i already changed that seal before when i bought my truck (bought at 47k now has 58). The seal is located at the end of the tranny right before the u-joints on the drive shaft. Has anyone experienced this? The leak is not much but its making a mess under my truck.
I put in an advance auto seal so maybe i should have gone with mopar. It easy to replace but i dont want to replace it if its going to leak again.
Share some light!
Share some light!
the front of my tranny pan is leaking where the two meet. ive been too lazy to take it up to dodge, still got about 4K miles left on my warranty
its only leaked enough to get part of the pan wet, nothing touches the pavement.
have you tried cleaning the pan thouroughly and then checking to see how quickly it leaks. i think we have what like 16 quarts, so a few oz wont matter.
Pull the drive shaft and make sure there is no groove or rough spots on the input shaft. Lightly sand with emory cloth to completely clean surface. Use a quality seal and replace the old one. Lightly oil the new seal with tranny fluid before re inserting the drive shaft. Should solve your problem.
I had the same problem with my F-150. Grab the driveshaft up by the slip yoke and see if it wiggles. There shouldnt bemuch play there. If there is(like my f-150) the there is a bushing issue in the extension housing. I never bothered fixing mine, just traded it in.
