Error code P0152, 2002 Ram 1500 ST Quad 5.9liter
Old Apr 4, 2008 | 05:29 PM
Jaytee67's Avatar
Jaytee67
Default Error code P0152, 2002 Ram 1500 ST Quad 5.9liter
I'm getting error code P0152, which indicates O2 sensor: "high voltage, bank 2, sensor 1", but there are several O2 sensors on the vehicle. Which sensor (location) is this referring to, and what is causing the error code to register??? Any help / advice would be appreciated. Thanks!
Old Apr 4, 2008 | 06:05 PM
daytona1680's Avatar
daytona1680
Default RE: Error code P0152, 2002 Ram 1500 ST Quad 5.9liter
bank 2 is passenger side, sensor 1 is the closest to the engine..and im guessing its a bad sensor.
Old Apr 4, 2008 | 11:58 PM
mmstar23's Avatar
mmstar23
had the same problem. i cant remeber if it was p0152 or p0155. it might have been the 55.... actually no, it was the one before the cat....the upstream...changed that and problems went bye bye. dont forget to reset your computer after installing it.
