Torsion Bar leveling q's
Old Apr 6, 2008 | 09:17 PM
johnsaballer's Avatar
johnsaballer
Default Torsion Bar leveling q's
Hey guys just a few general questions before i take the plunge. when doing the leveling the trucks front end should be up in the air right? I will not be doing offroading with the truck unless forced due to circumstance. that being said should i buy aftermarket keys or used the OEM's? and last question replace the front shocks or no? thank you all guru's that are Dodge Forum!
J
Old Apr 6, 2008 | 09:41 PM
bpv's Avatar
bpv
Default RE: Torsion Bar leveling q's
I'm going to be doing this too. There is lots of information here, you just have to search and read.
I've done my research and this is what I've learned so far:
1. Most people suggest lifting the truck on jacks to adjust the torsion, some claim that you don't have to lift it - personally i think lifting your truck on jacks just makes it easier.
2. I'm not aware of any OEM torsion keys to level your truck - just aftermarket.
3. This is up to you. From what I've read, sooner or later you will have to replace your shocks because changing the torsion bar setting will put the shocks out of their ideal range of motion and make them wear sooner. If you don't replace them you will definitely have a stiffer ride.
After all my research, my mind is made up to go with the truxxx kit mainly because of the stock relocation brackets. These brackets keep your shocks in their ideal range of motion which will maintain the OEM ride.
If any one has bought the truxxx kit please let me know about your experience.
Old Apr 6, 2008 | 10:34 PM
kx250frider617's Avatar
kx250frider617
no kit, i just cranked the bolts. For sure put the truck on stands so its effort less. i got pro comp mx6 shocks that are for a old toyota 4x4 but they work after changing out the bottom bushing. My rides a little stiffer more like a 2500 but its cool. My lift was free besides the cost for shocks.
Old Apr 6, 2008 | 10:37 PM
kx250frider617
this is how it sits
Old Apr 6, 2008 | 11:28 PM
HammerZ71's Avatar
HammerZ71
KX250: Love the stance, but you really gotta ditch the stock 20's and get you some nice aftermarket 17's and put some real meat on that 4x4...
Old Apr 6, 2008 | 11:32 PM
johnsaballer
i have to say 2.5" makes a whole lot of difference for your stance! I was trying to look for some 2" lift shocks. any suggestions for them?
Old Apr 6, 2008 | 11:45 PM
jonnymagnum's Avatar
jonnymagnum
is there any other way to level the truck out. I cranked the T bars on the dak, and it rode alot more rougher. I have 35x12.5's on mine right now and they rub a lil bit
Old Apr 7, 2008 | 12:31 AM
kx250frider617
oh trust me I would ditch the gay flower/butterfly wheels any day but I just don't have the $2000 to do it yet. But when I do I'll be rollin on black Teflon desert style wheels with some bfg at's
Old Apr 7, 2008 | 12:36 AM
mmstar23's Avatar
mmstar23
kx..is your front end slightly higher than your rear? i put my leveling kit in and my front wheel well measure about .5" higher than the rear.....hopefully thatl be fixed once i get new tires though.
Old Apr 7, 2008 | 01:02 AM
kx250frider617
Its some times higher the front or in the back but only when it wants too. But for the most part it sits literally perfect both are 14" from wheel well to top of rim.
