LED bulbs, Electronic Flasher???
Old Apr 8, 2008 | 01:00 AM
DaytonaDakota's Avatar
DaytonaDakota
Default LED bulbs, Electronic Flasher???
hey im thinking about buyin some led bulbs, but everytime ive ever messed with led bulbs i always get hyper flash where they blink flash. i believe this is from the factory flasher either under the dash or hood,
anyway im wondering if anyone has installed an aftermarket electronic flasher, if so where you may have bought it
or if anyone has put in led bulbs
Old Apr 8, 2008 | 06:55 AM
MikeHTally's Avatar
MikeHTally
Default RE: LED bulbs, Electronic Flasher???
The flasher is integrated with the instrument panel cluster. Many LED assemblies have the necessary load resistors, some need them added.http://autolumination.com/has a pretty good selection.
Old Apr 8, 2008 | 09:22 AM
dodgenitto's Avatar
dodgenitto
Check out ebay store "v-leds" I bought mine there! Or you can search ebay for "load resistors" They are easy to install! You will need a volt meter! All you have to do is remove the factory bulb and find which outlet is turn and brake! Those are the only two you need to splice a resistor on! Then you can screw it to the rear of your rear wheel well since they get hot! V-led's also sells some cool led lights that are just a plug in like your stock taillights!
These might not be the exact ones you are looking for but they are close!
[IMG]local://upfiles/79459/87C18F081DA8467AAC43C71D8B70D6DD.jpg[/IMG]
Old May 13, 2008 | 06:14 AM
luxlighting's Avatar
luxlighting
Dear All ,
How are you ?
Nowadays ,Led household bulb become very popular and widely substitute incandescent bulbs for indoor lighting because of high luminous and excellent heat sink solve
We are one of the manufacturer of these bulbs :
Led household bulbs: [/b]
MR11 9LEDS .G4 Bulb .[/b]
MR16 1W,3W,3*1W .GU10 1W,3W,3*1W ,JDRE27 1W,3W,3*1W .E14 1W,3W,3*1W .
PAR20 3*1W .PAR30 5*1W .7*1W .PAR38 12*1W .
Low power MR16 ,GU10 With 12LEDs.with reflector ( 0.72w) .PAR30 with 60LEDs( 3.6W)
Led deocration bulbs .led wall washer ,led underground lamps .[/b]
Led autobulbs[/b] : T10Wedge ,T15Wedge,BA9S ,Festoon 33mm ,37mm 42mm (.single chip .3chips) .red,yellow,blue,green ,cool white (6500k) .warm white (3000-3200k). .T25BA15S .
Thanks and best regards
Danny Duan
Export manager
shenzhen lux lighting technologies co.,ltd
www.luxledlight.com
Add: 904 ,124Building ,Mingle New village ,Longhua ,shenzhen ,china ,
Tel:0086-755-28096562 。0086-755-28096561-888
Fax:0086-755-28096562
E-mail: luxlighting@126.com / danny@luxledlight.com
Msn;gtl-guangzhou-danny@hotmail.com
Skype; sinocolighting
