Overhead Console Replacement
Old Apr 9, 2008 | 06:40 PM
quixin's Avatar
quixin
Default Overhead Console Replacement
Thanks to anyone in advance that can give me any help...
I have an 07 RAM 1500 with the standard overhead console which is missing the universal garage opener...
If I wanted to add the console w/ the garage opener, is it necessary to replace the entire console?
I've checked e-bay and found slim results... I can image the dealership will want an arm and a leg... I've also been unable to ontain any part #'s.
Thanks again.
Old Apr 9, 2008 | 11:25 PM
HemiLonestar's Avatar
HemiLonestar
Default RE: Overhead Console Replacement
Nope, if you have one without, all you should have to do is pull it and swap in the new electronic unit. The exterior piece is the same. There also shouldn't be any other wiring, since the Homelink should pull power from the same plug.
