swapping an 05 4.7 into a 02
Old Apr 12, 2008 | 09:21 AM
mtt04's Avatar
mtt04
Default swapping an 05 4.7 into a 02
I need your advice folks. I've got an 02 ram 1500 quad cab 4.7 that i use around town. It's got mega miles 110,000 or so. There's a wrecked 05 1500 4.7 i know of with about 10,000 on it. Great deal. Do you folks know if an engine, transfer case and tranny swap from 05 to my 02 would work. Would I need the ECU and all harnesses as well or can i use mine. I heard that this year was different than the 2002.
I'm new to mopar so your patience and thoughts would be appreciated. Thanks guys.
Old Apr 12, 2008 | 10:04 AM
oefootball_70's Avatar
oefootball_70
Default RE: swapping an 05 4.7 into a 02
should be the same. 02-05 are the same.
Old Apr 12, 2008 | 01:31 PM
HemiLonestar's Avatar
HemiLonestar
If you just swap the engine itself, the long block basically is what you need, unless your accessories are shot too, should be a straight swap. It will definitely go in, you may have to swap some small components, like sensors and whatnot. The best way to do it is get as much as you can with the engine from the donor, then take yours out (if you have the time) and set them next to each other. Start comparing. Go from there.
Old Apr 12, 2008 | 04:32 PM
tmodlin's Avatar
tmodlin
110k isnt that many miles. If it isnt broke dont fix it.
Old Apr 12, 2008 | 06:46 PM
killerbud420's Avatar
killerbud420
im not sure what year but somebody told me a while back that the newer 4.7 had more h/p...now im not sure what year or if it's true just what i herd[sm=confused06.gif]
