DeBadge
Old Apr 13, 2008 | 08:49 AM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: DeBadge
Go to a paint shop, they will have double sided "tape" for reapplying the badges.
Old Apr 13, 2008 | 09:48 AM
DRAM89's Avatar
DRAM89
Default RE: DeBadge
thanks bro. i dig your trucks
Old May 12, 2008 | 10:05 PM
trx450's Avatar
trx450
Default RE: DeBadge
i took my badges off but i am havin trouble taking off the glue that was under it, any suggestion on how to take it off with out wreckin the paint
Old May 13, 2008 | 09:10 PM
kniner's Avatar
kniner
Default RE: DeBadge
Well I just debadged the Ram. Man what a difference. Reference to removing the glue I used rubbing Alcohol and ALOT of elbow grease. Of course you need to use at least 3 towles, 1st pour alcohol and rub very hard. Use 2nd since the 1st now has the residue of the glue all over it. If you dont switch you'll make alot more work for yourself. After I used the 2nd rag I then sprayed the area with WD40 and did a quick rub. The 3rd cloth was sprayed with alcohol and I cleaned the whole area again. Now since I had the front of my truck repaired I noticed that since the paint and clear was faded into the passenger door I have a little lip of clear. I'll have to take a razor and slowly shave it down smooth and the compound it and wax it all out. Anyway though it does look alot better. Thanks guys for the idea on debadging.
Old May 14, 2008 | 01:38 AM
trx450's Avatar
trx450
Default RE: DeBadge
i went to a auto body shop and asked them and they told me to use paint thinner/ varsol for oiled based paint,
Old May 14, 2008 | 02:15 AM
HighDuke1911's Avatar
HighDuke1911
Default RE: DeBadge
i thought rubbing alcohol would murder your paint...
Old May 14, 2008 | 07:32 AM
kniner's Avatar
kniner
Default RE: DeBadge
I've used it on my other truck and had no effects. My buddy at US1 Auto used it for years with no problems. He just said don't leave it on there. Once done wash with soap/wax car wash. Now if the paint is alot different than the 95 I had oh well, we'll see.[&:]
