How do I adjust the door?
Old Apr 13, 2008 | 08:52 PM
mattsmall1972's Avatar
mattsmall1972
Default How do I adjust the door?
Yesterday I opened the door of my Ram to jump out. The wind caught it very hard and threw it open. Now I have a terrible wind noise when driving my truck from this door. When closed, the top of the door can be pushed closer to the truck, which would prevent the noise. I see on the forum that adjusting the door latch and/or striker can fix this. However, I don't see how either can be adjusted - they appear fixed in place. Am I missing anything?
Thank you,
Matt
Old Apr 13, 2008 | 09:20 PM
SmokeySportRam's Avatar
SmokeySportRam
Default RE: How do I adjust the door?
i think you f'ed it up, maybe bent the hinges.
check the hinge bolts, but i dont think there is adjustment. Sorry maybe someone else has better input.
Old Apr 13, 2008 | 09:38 PM
bpv's Avatar
bpv
Hmmm, I guess you could take some of the bolts out and throw some washers in there to shim it back... That's kind of a hack though
If it was my truck and the hinges were bent, I'd go to the auto recyclers and pick up a used hinge and replace the bent one.
Old Apr 13, 2008 | 09:51 PM
mattsmall1972
I did manage to adjust the striker but I'm not sure if it made any difference. I guess I'll find out tomorrow.
The hinge does not look bent in the least, but if this persists, I will go get a used hinge and replace it. The pillar that these doors are attached to does not look very string, to say the least. If replacing the hinge doesn't work, I think the shim idea will work. Any other ideas out there?
- Matt
Old Apr 13, 2008 | 10:02 PM
StevenMoffettKY's Avatar
StevenMoffettKY
So is it Matts Mall or Matt Small?
Old Apr 13, 2008 | 10:39 PM
RamItOne's Avatar
RamItOne
ORIGINAL: StevenMoffettKY
how much blue grass have you been smoking Steven?
Old Apr 14, 2008 | 12:20 AM
ryandun06's Avatar
ryandun06
the exact same thing happened to me...except it bent the top hinge and i took it to a body shop and they bent it back the best they could...it still doesn't shut right and when its windy out and im driving down the highway, the noise is terrible..so let me know if the new hinge works for you.
