add a leaf
Old Apr 16, 2008 | 10:32 AM
  #21
mmstar23's Avatar
mmstar23
Default RE: add a leaf
so i looked at the kit from pep boys....2 things....the damn u bolts arent perfectly round, and the u bolt isnt wide enough to fit around my axle.
do i really need the longer u bolts? and can i bend them to fit or will this not work?
Old Apr 16, 2008 | 11:58 AM
  #22
daytona1680's Avatar
daytona1680
ORIGINAL: mmstar23
measure the u-bolts on the truck and see if they are long enough, if your putting in 1" blocks then the stock bolts would need to have about 1 3/4" of extra thread on them. If they dont have enough thread on them then you will need the longer bolts. Its possible to bend the u-bolts, but it is a bitch. Your local hardware store should have the right size u-bolts, just need to know how wide andlong they need to be.
Old Apr 16, 2008 | 03:08 PM
  #23
mmstar23's Avatar
mmstar23
so i can get the block spacers from pep boys...and go to home dept and get u bolts?
Old Apr 16, 2008 | 03:17 PM
  #24
daytona1680
ORIGINAL: mmstar23
idk if home depot or lowes has them...I meant a real hardware store, ha ha..like ACE or True Value, or some kind of place like that. I know all the ACE stores around here have pretty much any size u-bolt you would need, last time I was there they had upto 15" wide u-bolts; id love to see what they are used for.
Old Apr 16, 2008 | 03:32 PM
  #25
mmstar23's Avatar
mmstar23
ok thanks, ill call ace. does anyone know what size ill need?i have a 2wd 9.25 rear axle.
and does the blocks stiffen the ride at all?
Old Apr 16, 2008 | 08:32 PM
  #26
Rot Weiss Essen's Avatar
Rot Weiss Essen
4WheelParts also has the block and Ubolt stuff for Rams and when I asked them about it I think they even could get a couple different sizes in the blocks depending on how high you want to go. I think they have the Ubolts custon made locally, but they are heavy duty which is nice. I can't remember how much they are, but it isn't much. I might do the same thing to mine as now the front looks a hair higher, but I might even go with the 3" body lift I don't know yet. Depends on how big the 35's look on it without the body lift? We will see.
Old Apr 16, 2008 | 08:34 PM
  #27
Rot Weiss Essen
And no, it won't stiffen the ride and you won't have the noise problems you get with the add a leaf.
Old Apr 16, 2008 | 10:19 PM
  #28
mmstar23's Avatar
mmstar23
ok, so i called around and home depot and ace has them...those are the only places i tried. however the guy at home depot said there may be a load rating on it? and the one from there might not be heavy duty enough????
ya i have the 3" body lift and the 2.5" level....im throwing 35's on soon man.
Old Apr 16, 2008 | 10:24 PM
  #29
RamItOne's Avatar
RamItOne
35"s in the rear and 33"s in the front,, thatll even em out... have you gotten the allignment done yet?
Old Apr 16, 2008 | 10:38 PM
  #30
mmstar23's Avatar
mmstar23
nope. ill fix my ball joint, take care of my front shocks and then get me the tires. when i go to have the tires mounted...everything that can be wrong with it will be fixed. camber, caster, aligned, balanced. everything!
