front axle U joints - 2004 2500 diesel 4wd
Old Apr 15, 2008 | 01:57 PM
bunkytadwell's Avatar
bunkytadwell
Default front axle U joints - 2004 2500 diesel 4wd
I just had the U joints on both sides (L&R)of the front axle replaced. Now, it was aggravating enough to have to had the rear drive shaft U joints replaced (twice), but now the front axle U joints??
The truck steered like it was in 4WD all the time and in sharp turns if vibrated like it was a JT8D firing up on an old 737.
Truck has 40,000 miles.
So, when I inquired as to why the axle U joints had to be replaced at 40K miles, I got a grin and a shrug and he told me that this was common.
Does anyone know of a better U replacement U joint instead of using the Dodge joint? Perhaps one that will run for a lot longer, and maybe has a Zerk fitting?
I have owned dozens of jeeps and never had a bad axle U joint ever.
Thanks in advance....
