installing mudflaps/ splashguards
Got a set of used mudflaps today. Theyre the OEM molded splashguards, all four.With them came a few white plastic push type things, a few plastic black ones and a few screws.
Before I get a chance to go out & mess with it, which ones are for where? Closeup install pics.? Thanks
This is how I mounted mine. I used two of the supplied black screws and two 3/8 stainless steel bolts/nuts (from the hardware store) for added strength. The black screws are using existing factory holes already in wheel well but I drilled the 2 holes through the flap and liner for the bolts. You need some screw washers/tabs that the screws need to go into. Those can be obtained at the dealer.
Hope this helps. Pics attached.
Tim
Tim
The pastic parts go in through the holes on the far inside part of the flaps. You have to drill a hole into the wheel well liners for them to go through.
Those mudflaps look different than the ones on my '06 so I can't really help with the install. Each flap has two bolts one screw and one black plastic push thing holding it on.
ORIGINAL: red06RAM
Two screws on each wheel well edge, one under the body (screw fronts, bolt rears) and 1 plastic push in on each flap.
I got my flaps at the dealer and they installed them for me when I picked up the truck. Guess it was my first mod. Tried to get them to "throw them in" but it didn't work.
Trending Topics
ORIGINAL: red06RAM
94rt10ohio, thanks again. I guess it doesnt matter if you use the black or white push things in the front or back?
