Rear Gear Ratio??? - 08 Ram 1500 Big Horn ->
Old Apr 20, 2008 | 05:42 PM
5corpi9's Avatar
5corpi9
Default Rear Gear Ratio??? - 08 Ram 1500 Big Horn ->
Where on the truck do I find the Gear Ratio?
Old Apr 20, 2008 | 05:51 PM
CarGuyOhio's Avatar
CarGuyOhio
Default RE: Rear Gear Ratio??? - 08 Ram 1500 Big Horn ->
That is a good question, might be on the sticker inside the door, but it is probably a code.
08, you bought it new? If it is not in the window sticker over in the optionsthen you have 3.55s as that is the standard.
Old Apr 20, 2008 | 06:04 PM
SeMiGoD's Avatar
SeMiGoD
I know manufacturers USED to put a tab right on the differential off the bolts stating the gears. Not sure if they still do or not tho, wouldnt hurt to take a look.
Old Apr 20, 2008 | 06:14 PM
Bones1274's Avatar
Bones1274
I have a 08 Bighorn Hemi and it was on the window sticker. I have the 3.92 gears.
Old Apr 20, 2008 | 06:47 PM
MikeHTally's Avatar
MikeHTally
If it has 20" wheels, it's most likely a 3.92. Look on the glovebox door, or look for a tab on the diff. It'll probably say "39"
Old Apr 20, 2008 | 06:55 PM
Parts/Service's Avatar
Parts/Service
PM me the last eight digits of your VIN and I can tell you what you have....
Old Apr 20, 2008 | 08:30 PM
5corpi9's Avatar
5corpi9
Thanks for all the info...I will check....
