05 Ram not shifting
Old Apr 22, 2008 | 06:49 PM
AdamBailey's Avatar
AdamBailey
Default 05 Ram not shifting
I have a 2005 Dodge Ram Hemi. It has Superchips Flashpaq, LT headers, andAEM bruteforce intake. When you got WOT and it goes to shift it just bangs the rev limiter until you just barley let off the gas and then it shifts. Any help would be greatly appreciated. Thanks
Old Apr 22, 2008 | 10:22 PM
buganddoug's Avatar
buganddoug
Default RE: 05 Ram not shifting
It sounds like the TPS ( Throttle positioning sensor ) is going bad.
Old May 4, 2008 | 03:31 PM
AdamBailey's Avatar
AdamBailey
I called and tried to order one from Dodge and they said there is no such item for a 2005 Ram Hemi.? Anyone got a part #?
Old May 4, 2008 | 04:12 PM
tigman250's Avatar
tigman250
not sure if the Flashpaq allows you to move the shift points or not but try knocking them down a bit, my truck was doing the same thing after the premium download from my Bully Dog so i had to reduce the shift points a bit.
Old May 4, 2008 | 04:19 PM
HammerZ71's Avatar
HammerZ71
Take the Flashpaq out of the equation.Return the truck to stock, then see what happens. If it shifts normally, then re-install the tune and drop the shift points a bit.
This will tell you if you have a real tranny issue or if it's the tune...
Old May 4, 2008 | 05:06 PM
AdamBailey's Avatar
AdamBailey
ORIGINAL: HammerZ71
I tried doing this but I'm not sure if I'm actually taking the tune out. When I bought the truck it had the Flashpaq already installed. I guess if I select stock, then it should return it that way? It just doesn't seem like a difference to me.
Old May 11, 2008 | 09:02 PM
AdamBailey's Avatar
AdamBailey
Okay, I finally got the truck to take the stock program. It shifted perfect. Any suggestions on why the computer would make the truck act like that when it goes to shift?
Old May 12, 2008 | 12:02 AM
deanj287's Avatar
deanj287
you wouldnt happen to have 4.56 gears would you? other wise it seems its jut the superchips tune if you went to stock and shifted perfectly...
