transmission fluid check
Old Apr 24, 2008 | 11:01 PM
Stunnerguy's Avatar
Stunnerguy
Default RE: transmission fluid check
That's all I got here, NAPA like 45 min away, autozone and o'reilly are only 5 mins away
Old Apr 24, 2008 | 11:02 PM
RamItOne's Avatar
RamItOne
too bad theyll all still ask you for the engine size when you're looking for wiper blades. Lmao!!
Theyll also swear that platinum plugs are better and that they don't even list a copper option. Pretty bad when their cross ref prog doesn't have oem plugs. They have em just got to give them the part #
Old Apr 24, 2008 | 11:05 PM
RamItOne's Avatar
RamItOne
as for using rtv, nothing wrong with it, except a guy in second gen couldn't get his tranny pan off for the life of him. I told him a trick and it worked, but gaskets make it much easier to break off the plate. Also you don't have to sit there with a scraper and brake cleaner.
Old Apr 24, 2008 | 11:24 PM
Stunnerguy's Avatar
Stunnerguy
yea must of took me 4 hrs to do the job. Such a pain in theass to scrape that RTV off the pan. I should of just waited, it said do ur transmission at 100k and I only have 70k on my truck.
Old Apr 25, 2008 | 12:30 AM
RamItOne's Avatar
RamItOne
stunner did you use brake cleaner? It helps to get the rtv off.
Old Apr 25, 2008 | 01:53 AM
Stunnerguy's Avatar
Stunnerguy
no, i'm not that bright, I used razor, filer, and sum soapy water
Old Dec 23, 2019 | 04:26 AM
Dr. Anh Thai's Avatar
Dr. Anh Thai
Yes, It happens. I had the same issue. Do not know why. Please advise, thanks.
Old Dec 23, 2019 | 12:42 PM
Alex Medeiros's Avatar
Alex Medeiros
It's an 11 year old forum...
Old Dec 23, 2019 | 10:22 PM
Dr. Anh Thai
Thanks Alex. But the truck still here. Any idea about the note from Stunnerguy "I just changed my transmission fluid in my 03 dodge ram 1500. The dipstick has the level for when it hot and when its cold. when the vehicle is cold its in the hot range and when it hot its in the cold range. I just brought the truck and I'm freaking clueless on wut to do. I've never had this problem before."
I could not see any directed respond to the problem any where from the Internet.
Old Dec 24, 2019 | 01:46 AM
Dodgevity's Avatar
Dodgevity
Check the ATF as detailed in post #2, however, check while in NEUTRAL, not park. You're doing this at operating temp, so after driving, pull in somewhere flat. Don't worry about anything else, like cold level, etc.
