transmission fluid check
Old Dec 24, 2019 | 08:36 AM
  #21
Dr. Anh Thai's Avatar
Dr. Anh Thai
Default Transmission level shows on the upper dot at COLD, but does not show when hot
Check the ATF as detailed in post #2, however, check while in NEUTRAL, not park. You're doing this at operating temp, so after driving, pull in somewhere flat. Don't worry about anything else, like cold level, etc.
Thanks Dodgevity. As many members said the same thing as well as note on the manual. In this case, I think I should rewrite this note on manual then check back with manufacturer.
