drivers rear door stped working
Old Apr 24, 2008 | 02:06 PM
memphisii's Avatar
memphisii
Default drivers rear door stped working
so on my 06' 3500 the drivers rear door stoped locking and unlocking and the lights no longer works when the door is opened, a swapped out the door switch/ latch and checked the wiring both are good any one seen any thing like this or have any info that may help thanks.
Old Apr 24, 2008 | 04:32 PM
MikeHTally's Avatar
MikeHTally
Default RE: drivers rear door stped working
Does the power window work? How 'bout the speaker in that door? If not, it would seem the wiring harness needs some attention. Is that door used a lot? I've heard of the wiring harnesses getting stressed and losing connectivity.
Old Apr 24, 2008 | 04:45 PM
jstmahoney's Avatar
jstmahoney
If it is still under waranty take it to the stealership, It's their problem. If not check out what Mike said. If everything else works maybe a Door actuator?
