New Big Horn
Old Apr 26, 2008 | 03:59 PM
Mr.B's Avatar
Mr.B
Default New Big Horn
Howdy,
Anybody have any experience with the Helwig sway bar?
THX B
2008 Ram 1500 4x4 5.7L
Cold Air Intake
Magnaflow Exhaust
Line-X
Tuff Country Leveling Kit
[IMG]local://upfiles/88151/5376BF86925E48169D78793386462141.jpg[/IMG]
Old Apr 26, 2008 | 04:13 PM
MikeHTally's Avatar
MikeHTally
Default RE: New Big Horn
Welcome to the forum and congratulations on your new ride. Yes, I put a Helwig on my truck last fall. Probably the best single performance mod I've done. The truck handles much better than stock. There are some s-curves near my house. Before the Helwig, 'bout the best I could do in those turns without the tires complaining was a bit over 60. Now, the tires don't complain until I get to a bit over 70. The sway bar also improved turn-in and steering response. It's an easy installation. If you decide to get one, take the time to run the nuts all the way onto the u-clamps and the threaded rods before installation using WD-40 to make that easier. For some reason, they don't thread their stuff very well. Be careful around brake lines. Make sure they don't rub or get trapped under the clamps. One more thing, if you plan to get an aftermarket exhaust, do the sway bar FIRST! I had to have my Magnaflows touched up after the swaybar went in.
Old Apr 26, 2008 | 07:37 PM
The Peddler's Avatar
The Peddler
Welcome to the forum!! Nice truck!
Old Apr 26, 2008 | 08:57 PM
thehemiman12345's Avatar
thehemiman12345
Nice looking truck.....i've only heard good things about swaybars for these trucks also.....good luck with it.
Old Apr 26, 2008 | 10:37 PM
Hemipwr07's Avatar
Hemipwr07
nice looking truck dude. we hav all the same mods pretty much ha
Old Apr 27, 2008 | 01:23 AM
Mr.B's Avatar
Mr.B
Thanks for the info.
The only complaint (albiet small) I have is the sway. Just changing lanes on the freeway will cause too much sway...OK I'm a little ham-handed but its a truck! Oh, and this is worse at around 70-80 mph.
Anyway, I was wondering if the sway bar would negate any handling parameters that may have been designed by Dodge. I wouldn't want to prevent some "sway" that Dodge may have intended to keep the truck upright.
Otherwise....luv the hemi!
B
Old Apr 27, 2008 | 01:29 AM
Mr.B's Avatar
Mr.B
I also debadged the big "bighorn" thing on the tailgate. In doing so, I screwed up the paint some, as well as some discoloration where the adhesive was.
Any ideas on a descent fix? Maybe some light rubbing-compound?
Thanks
B
