Woo hoo and boo hoo
Old Apr 28, 2008 | 10:47 AM
CarGuyOhio's Avatar
CarGuyOhio
Default Woo hoo and boo hoo
I changed the differenital fluid this weekend. C-Clips are A-OK. But.... As I was laying there I saw some grease on my gas tank, after a closer look the pinion seal appears to be at the begining stages of failing. I was at the dealership a couple weeks ago just before my 3/36 ran out and asked them to check over the truck, obviously they missed this. Not sure if the pinion seal will be part of the 7/70 drive train, but I either way they better fix it given they were to "check over" the truck.
Old Apr 28, 2008 | 10:56 AM
MikeHTally's Avatar
MikeHTally
Default RE: Woo hoo and boo hoo
I thought the pinion seal was on the differential. Wouldn't that put it aft of the tank?
Old Apr 28, 2008 | 11:46 AM
CarGuyOhio's Avatar
CarGuyOhio
As the drive shaft/yoke spins it tosses the lube onto the rear part of the tank, underside of bed.
Old Apr 28, 2008 | 12:26 PM
MikeHTally's Avatar
MikeHTally
Ah.
Old Apr 28, 2008 | 02:29 PM
oefootball_70's Avatar
oefootball_70
oh, that might be why my under body has a black grease on it?
Old Apr 28, 2008 | 02:32 PM
derricksmash's Avatar
derricksmash
V6 Ram Moderator
^^ no, it's because you have a red truck.
Old Apr 28, 2008 | 02:33 PM
CarGuyOhio's Avatar
CarGuyOhio
ORIGINAL: oefootball_70
Highly likely. It would be under the bed directly above where the drive shaft meets the differenital, and you would see some on your gas tank as well as on the differential near the drive shaft. When it gets worse you will have drips in your driveway.
