Front leveling & tire rub on an 08 Ram 1500 2wd...
Old 04-30-2008, 05:17 PM
oefootball_70's Avatar
oefootball_70
oefootball_70 is offline
Default RE: Front leveling & tire rub on an 08 Ram 1500 2wd...
1/4" IMHO dont use. its just a piece of metal that goes in-between the wheel and hub. 1.25 doesn't look bad. If you want the wheels fitting under the truck perfectly then its just not gonna happen. You should get new wheels.
Old 04-30-2008, 06:03 PM
Scott06HEMI's Avatar
Scott06HEMI
Scott06HEMI is offline
I used 1/4" spacers just to stop the wheel from rubbing the upper arm and it worked fine. i definitely wouldn't use anything bigger than 3/8" because of the stress on the studs. I disagree with the thought of just getting new rims. I like my factory 20" rims and don't like the look of most after market rims.
Old 04-30-2008, 08:31 PM
HEMI07's Avatar
HEMI07
HEMI07 is offline
Romeosoldier03 has 1.25" spacers on factory 20" wheels. In the search box for this forum, type "ROMEOSOLDIER03" and his posts will come up with pics of his truck. It looks awesome with the spacers and the 36" Iroks
Old 04-30-2008, 10:06 PM
5corpi9's Avatar
5corpi9
5corpi9 is offline
I'm trying post pics, but I keep getting the "File to Large" message...What's the max a pic file can be?
Old 04-30-2008, 10:19 PM
mmstar23's Avatar
mmstar23
mmstar23 is offline
im not going with the huge spacers, but i will get the 1/4" spacers. i just need it to clear the control arm and suspension pieces.
and ya i forgot, romeo has factory wheels. he needed the 1.25" spacer to clear the 13.5" wide tire.
hows the tread wear on your xtreme a/t's?
Old 04-30-2008, 10:28 PM
5corpi9's Avatar
5corpi9
5corpi9 is offline
One thing I can tell you about the Pro Comp Xtreme A/T's are that they are very quite on & off the highway!
As far as tread wear, only had them for a day...
I am looking for 1/4" wheel spacers...Can anyone send me a link of a good heavy duty one? I will be towing a trailer and don't want those spacers going out on me with the Toy Hauler behind! [:-]
Also, am I looking for 5 lug on 5.5 bolt pattern? And what tread / studs am I looking for?
Thanks...
Old 04-30-2008, 10:39 PM
5corpi9's Avatar
5corpi9
5corpi9 is offline
What is IMHO Spacers?
Old 04-30-2008, 10:47 PM
oefootball_70
In my humble opinion
Old 04-30-2008, 10:55 PM
5corpi9's Avatar
5corpi9
5corpi9 is offline
Thanks Oefootball_07...
Why do you say (in your opinion) don't use spacers?
My main concern is to get the strongest spacers, weather it be the 1/4", or the 1.25" spacer that has another set of lug nuts, to support the towing of the trailer...
Any suggestions?
Also, if I go with the 1.25" spacers with lug nuts, how much more "Out" will it bring the tires???
Thanks...
Old 04-30-2008, 11:03 PM
mmstar23's Avatar
mmstar23
mmstar23 is offline
what do you mean....its 1.25"..then it pushed the whole rim and tire out....1.25"
Quick Reply: Front leveling & tire rub on an 08 Ram 1500 2wd...
