First oil change question
Old Apr 30, 2008 | 08:24 PM
Ironhead's Avatar
Ironhead
Default First oil change question
When should I do my first oil change? 500, 1000 or 3000 miles?
Old Apr 30, 2008 | 08:28 PM
RamItOne's Avatar
RamItOne
Default RE: First oil change question
i did mine a lil past 6,000
Old Apr 30, 2008 | 08:38 PM
Bones1274's Avatar
Bones1274
My odometer flashed the change oil warning at 2600 miles. The book says 6000 miles.
Old Apr 30, 2008 | 09:59 PM
tafet's Avatar
tafet
It depends on what type of oil it came with. If its petroleum I'd change it at 3000. If it's synthetic I'd wait until 5000-6000. Since you have a new truck that isn't fully broken in yet you might want to stick with petroleum until around 10,000. After that I'd make the switch to full synthetic. Just my opinion.
Old May 1, 2008 | 08:40 AM
#Red's Avatar
#Red
The truck sounds new, I would go just shy of 3,000. That is when I do my oil changes. Red
Old May 1, 2008 | 09:16 AM
RamMan25's Avatar
RamMan25
My truck has 200 miles on it, I was planning on converting it to Mobil 1 synthetic at around 3-5000 miles, would this be ok?
___________________________________
2008 Dodge Ram 1500 4x4 Hemi
Old May 1, 2008 | 11:00 AM
Horseapples's Avatar
Horseapples
I brought mine home from the dealer and switched to Penzoil Platinum full synthetic on the same day. The old way of thinking was that one needed to run dino oil for a while to let all the rubber seals swell and seal before using synthetic oil. However all seals and gaskets are now made from synthetic rubber instead of natural rubber so switching to synthetic at any time is ok. I am hard on engines and change my oil every three thousand miles. for regular service, 5 to 6 thousand would be fine. Use a quality filter, Wix is A great one and will be available at most local part stores (wix also makes the NAPA gold series filters). Every piece of heavy equipment I ever worked on had Wix filters, thats what first opened my eyes to filter quality. If thay are good enough for bull dozers and track hoes, there good enough for street trucks!
There are many good filters on the market besides Wix, like K&N, and Amsoil, but these cost A lot more. Hope this helps!
Old May 1, 2008 | 11:02 AM
CarGuyOhio's Avatar
CarGuyOhio
I changed my Hemi at 3K with M1 syn. The truck has never had any mechanical failure due to the oil. I change every 5K with the syn.
Old May 1, 2008 | 11:27 AM
tntitans21399's Avatar
tntitans21399
You really only need to do it every 6,000 miles. The oil companies (jiffy Lube, etc...) will tell you every 3,000 so you will come in more often, but you only need to every 6,000 miles.
