Gas guage problem
Old Jun 3, 2009 | 09:25 PM
sos's Avatar
sos
I think it's probably something to do with the sending unit. That's the part that has the float and tells the gauge how much gas is in the tank. It's either a connection on the sending unit, or the unit itself.
Old Jun 4, 2009 | 12:18 AM
RedTruck-VA's Avatar
RedTruck-VA
Default gas gauge problem
Originally Posted by ulte1383
I have an 03 4.7L Ram with a problem. About 80-100 miles into a fresh tank of gas, the low fuel light comes on, the audible low fuel warning comes on and the gas guage goes to zero! Turn the truck off and back on......everything is fine. I will be selling this truck later in the summer and would like to get it figured out without the dealers $$ help. Anyone ever heard of this problem?
Thanks
I have the same problem with my 03 Ram 1500 5.7L. The code is high voltage level or something like that. I disconnected my battery while working on the CAI for about 20 minutes which provided a cold boot for the computer. I haven't had the problem for about two weeks.
Don't really no what the problem is/was but it had become pretty constant before the reboot.
If you identify the actual problem please post it.
Good luck...
Old Jun 4, 2009 | 08:28 AM
FireRescue J-16's Avatar
FireRescue J-16
Everybody that said to wiggle the connections on the tank is most likely right.
One of my friends had a 91 4runner and his started doing the same thing except it was dying and stop lights and wouldn't idle for more than 30 seconds without cutting off..
We replaced all the fuel lines, filter (BPITA!!), sending unit, injectors, and fuel pump..
It turned out to be a loose ground on the fuel pump causing all the problems. >_<
But hey, it had an all new fuel system when he sold it! lol
