Transmission, Will this fit ?
Old May 4, 2008 | 12:40 PM
shadow kennels's Avatar
shadow kennels
Default Transmission, Will this fit ?
Hello
I would like to know, my 2002 Dodge Ram 5.9l (Gas) has a 46RE transmission 4 speed automatic.
Can I swap/change to the newer 45RFE four/five-speed automatic on my truck ?
If so, is it a straight swap or will I need some extra parts ?
Thanks.
Zoi
Old May 4, 2008 | 07:53 PM
ivaskaj's Avatar
ivaskaj
Default RE: Transmission, Will this fit ?
I'm sure it's not a direct bolt in. It is probably not the same length, so you will need a new driveshaft. It probably uses a different bellhousing bolt pattern, so you would have to make a custom adapter. Then there is the matter of the computer controls for it. you would need to get a computer from a 5spd auto truck and wire it up somehow, or see if anyone makes a stand-alone computer for it. Oh, and a custom crossmember would probably be needed. You would be better off having your stock one built so it won't keep blowing up all the time.
Old May 5, 2008 | 12:23 AM
shadow kennels
Oh I have no real problems with my tranny, but thanks for the advice, as for the answer to my dilemma ?
Thanks, I just wanted to know, (a tranny was for sale and wanted to know if it was able to buy one that was being sold as a,
"spare."
Thanks.
Zoi
