Power Steering only working when giving gas
Old May 4, 2008 | 06:04 PM
defektion's Avatar
defektion
Default Power Steering only working when giving gas
Hey guys, My problem starting with whenever i would turn the wheel sharp the power steering would make this whining sound, but it worked fine. And now just a few days ago my power steering doesnt work very well if im not giving it gas. Its like it needs me to have a certain rpm level before the power steering will work. Any ideas? Its it something with the release valve or can it be bled? mabey air in there? I filled up the resevoir, so its good on fluid
Old May 4, 2008 | 07:18 PM
Gone Fishin's Avatar
Gone Fishin
Default RE: Power Steering only working when giving gas
Sounds like its time for a new pump.
I pulled the level stick on mine yesterday while I was changing the oil. Found a lot of real fine black particles on the stick. I'm going to be flushing and re-filling mine shortly.
Makes me wonder what the composition of the gears are. I haven't had any problems, but also don't want any either
I suggest you replace the pump very soon--as either your pump is going dead.
Does anybody know if a pressure regulator/ reliefis used in these??????
