cranking tbars = not level?
Old May 7, 2008 | 12:26 PM
kenihemi's Avatar
kenihemi
Default RE: cranking tbars = not level?
Couple of things I found out.
If you crank them up too far, you'll be topping out the shocks, meaning they don't have much travel upward.
I cranked mine about 4-5 complete turns and it wasn't enough.
Then I put in a set of Ground Force drop shackles that did the job pretty good.
Old May 7, 2008 | 12:56 PM
HammerZ71's Avatar
HammerZ71
ORIGINAL: kenihemi
Yea, I've found anything more than 2" of lifting the front and the shocks can bottom out fairly easily off-road or even going too fast over speed bumps. 2" really looks a lot better than stock, but it's not perfectly level, it really takes 2.5" to get it perfectly level and that's asking a lot out of a t-bar crank. If you want it perfectly level AND plan on off-roading, then I'd strongly suggest a level kit and if you don't also plan on new, longer shocks, then get a kit with the relocation brackets.
I just think the t-bar crank is a nice FREE way to get a little better look and clear a little bigger tire.
Personally, I'd never do thedrop shackles thing. But that's just me, I just don't believe in lowering anything, ever!!!
Old May 7, 2008 | 03:11 PM
mmstar23's Avatar
mmstar23
some have gotten away with not getting new shocks after a leveling kit......but i dont have new shocks and i got a 2.5" leveling kit...and damn do you need new shocks. after tires.....maybe even before, longer shocks are going in!
