PACESETTER LT HEADERS....
OK....AIRRAM!!!! I bought them off of airram.com what is the power wire??? just curious...but i did order the ceramic headers though...thanks alot...now im phyced up for em....
Good deal, you're gonna love that mod! You'll see an immediate boost, especially from about 2500 rpm & up, plus (if you cant stay off the gas) a modest mpg gain as well.
You gonna put them in yourself or have it done?
I bought the same ones, but got them uncoated and had a local shop coat them. Just a little better/thicker coating that way. Paying a little more for the ceramic coating not only protects them from corrosion and discoloring, but REALLY helps scavenge the heat out from under the hood and out the exhaust. You'll be real glad you got them...
Pics of mine before I put the well liners back in:
[IMG]local://upfiles/67238/649533D6F20C4E688EBABC0864B6BD5D.jpg[/IMG]
[IMG]local://upfiles/67238/6503481AA2794046A23CB6B2903A6E01.jpg[/IMG]
ORIGINAL: XxSilentHawk99xX
Where would you go to get your headers ceramic coated after you purchased them? I just ordered a set of JBA stainless steel ones from Airram..
I bought mine from KRC and they suggested using a shop in Orlando that does ALL there coating work, so I had them drop shipped there and picked them up from them when it was done. The guys at KRC said the factory "Jet Hot" coating is good, but this shop does it every day and uses a much thicker, durable coating inside & out.
I was just gonna order them coated from Air Ram or Moe's, but felt obligated to get them from KRC since I pick their brains all the time, but don't give them much work as I prefer to do most of my mods myself, plus the custom coat idea sounded good to me. They were a little higher on the headers, but not out of line. Plus, getting them plain and having the better coat put on only added about $75-$100 over the cost of odering the Jet Hot coated ones...
ORIGINAL: daytona1680
The only thing I will suggest is to get a set of the mopar exhaust manifold gaskets, the gaskets pacesetter sends are junk.
Trending Topics
..I did my own cam install....as well as 13 others at my house..lol.... where are you located, i may know a member on one of the boards that can help you out... I've heard dealers/mechanics chargin upwards of $1000.00+ ... we doem for way less and have a gtg at the same time..
[IMG]local://upfiles/13436/753A957CE453459D9ACD9BC7A2D549A2.jpg[/IMG]
[IMG]local://upfiles/13436/4263A1A0CDF845B39592E30E7639E82C.jpg[/IMG]
