Maintenance question
Old May 5, 2008 | 11:58 PM
JustAnotherForumID's Avatar
JustAnotherForumID
Default Maintenance question
Hi all: New to the forum. Had my 04' Dodge Ram Quad Cab, 4x2, 4.7L (66K miles) at the dealer the other day for oil change, tire rotation, and state inspection. The service manager came over while the truck was in the shop and wanted to sell me:
transmission flush
rear diff fluid change
power steering fluid flush
replace spark plugs
I've owned the truck since new andI don't beat on it. She looks and runs perfect. But in all honesty, I have not had anything done to it except for regular oil changes, one set of tires,and 1 air filter replacement.
For those in the know, which of the above services are truly required at this point? As others can relate, I am really watching my spending lately and I don't want to throw money away unnecessarily. However, I don't want to deprive my truck from needed services.
Let me know your thoughts. Thanks!
Old May 6, 2008 | 12:03 AM
RedneckDodge86's Avatar
RedneckDodge86
Default RE: Maintenance question
Well for one i definitley reccomend the spark plug replacement. The power steering u can do youself. The tranmission i would have done also but that is me and i baby my truck. It doesnt cost much to keep the fluids new but it costs alot to fix it if something goes wrong cause you didnt. Just my opinion. But i got with the spark plugs and tranny for sure. Pretty sure you should flush your tranny every 30k miles but im not sure.
Old May 6, 2008 | 07:38 AM
HammerZ71's Avatar
HammerZ71
Tranny & power steering are 30k items, so you are WAY overdue.
In a 2wd, the rear diff should be done at about 60K, so it's due.
The plugs should also be done at about 30k, so you need to do them.
All but the tranny is easy and can be done in the driveway. That's where you can save yourself some labor $...
Old May 6, 2008 | 08:31 AM
RamItOne's Avatar
RamItOne
plugs you do yourself, unless your hammer and have a hemi and would rather find out what 220 feels like by touching the water heater than dicking with 16 plugs...
you know tranny changes is a crock, a new engine isnt gonna have metal filings, its got a lot of detergent in it, as long as you dont tow or over heat your fluid its more of a scam than help...if you do change it, use amsoil and forget about it..
why are we told every 3k miles yet the same mfg in UK says every 12K? its because their environmentalists wont let wastefull pollution occur like here in the states.. so same car different country different intervals, you tell me if its mechanical need or greed that says change your oil every 3k miles?
also with plugs, my buddy changed his factory champs at 92,000 miles, didnt notice a damn diff in driving, accel, fuel econ...
Old May 6, 2008 | 11:32 AM
dreman's Avatar
dreman
ORIGINAL: JustAnotherForumID
transmission flush
replace spark plugs
Get the maintenance schedule out of your owners manual and do what it says is required when it says to do it. If you don't have the owners manual, look up the electronic version of it at the Dodge website.
Don't just believe the dealership service manager on maintenance intervals, although it sounds like those are what is called for in the owners manual. Some service managers will show you an "updated" maintenance schedule that has more things on it to do and more often. it just increases the work they can charge you for, without any real benefit to you or your truck.
Old May 6, 2008 | 12:16 PM
kenihemi's Avatar
kenihemi
You defininety need new plugs. I suggest the stock Champions.
Trans fluid/filter, but I wouldn't do the flush bs.
Rear diff fluid and clean out.
Old May 6, 2008 | 02:22 PM
MikeHTally's Avatar
MikeHTally
None of this stuff is too hard to do, if you've done some vehicle maintenance in the past. Tranny fluid is messy to change, but relatively easy. The manual is 30K for that. Flat filter every time, spin-on every other time. Rear diff is every 15K. Easier than the tranny and not quite as messy. Keep an eye on the coolant. Probably OK, but get one of those inexpensive testers to be sure the protection is up-to-snuff.
Old May 6, 2008 | 03:09 PM
ramman59's Avatar
ramman59
I like the girl
Old May 10, 2008 | 12:52 AM
whiteonrice's Avatar
whiteonrice
Trans flush is BS. Take the $100 and rent a hooker. You'll feel better and your trans will be better off.
Rick
Old Apr 2, 2009 | 03:53 PM
TheFist's Avatar
TheFist
This link says not to do tranny service until 60k miles.
https://dodgeforum.com/forum/3rd-gen...intervals.html
