pics needed of lifted ram with factory twenty's and bigger tires
Old May 7, 2008 | 05:56 PM
  #21
HEMI07's Avatar
HEMI07
Default RE: pics needed of lifted ram with factory twenty's and bigger tires
just measured again on level ground this time and its 44 1/2 in the front and 45 1/2 in the rear. I checked it at all 4 wheels.
Old May 7, 2008 | 10:10 PM
  #22
mmstar23's Avatar
mmstar23
how tall was your leveling kit? mine was 2.5". i know i have a 1" block in the rear, but if you think of physics....lifting the rear would actually drop the front slightly. im very confused how my 2wd sits just as high as scotts 4x4 with 35" tires when mine are 30.5.....and when i get my 35" tires ill be about even, if not a tiny bit more than HEMI07. but once again...he has a 4x4.....
speaking of overload shocks....romeo said they added an inch? now are those just stiffer shocks or what? because where ever i can get some lift in, im all for it haha. but stiffer shocks would make the ride a lot rougher correct?
Old May 7, 2008 | 10:12 PM
  #23
mmstar23's Avatar
mmstar23
by the way, hemi07, please update your pictures in your album, i keep going to look at your truck and its how it was stock. i want to look closer at the new truck with the lift! and get larger pics too, i wanna SEE your truck, it looks great!
Old May 7, 2008 | 11:02 PM
  #24
Romeosoldier03's Avatar
Romeosoldier03
doesnt help much but here's a pic of my nephew standing in front of his toy.......it outta help a lil hopefully.
[IMG]local://upfiles/84191/9C7E590CCA9E429A8A1A0B5D69BF2C6A.jpg[/IMG]
Old May 8, 2008 | 08:11 AM
  #25
HEMI07's Avatar
HEMI07
I will try and update pics today mmstar23
Old May 8, 2008 | 08:55 AM
  #26
mmstar23's Avatar
mmstar23
thanks hemi....its weird also, that your truck looks A LOT higher than mine. but measurements are the same. i dont get it at all.
Old May 8, 2008 | 09:29 AM
  #27
Scott06HEMI's Avatar
Scott06HEMI
started a thread for truck height this way others can join in...
https://dodgeforum.com/m_1304692/mpa...tm.htm#1304692
Old May 9, 2008 | 12:15 AM
  #28
getnarked100's Avatar
getnarked100
Hi guys -
New to DF and came across this conversation while sneaking a peak at your lift pix, all of which are very nice by the way...and from a chick's point of view...I gotta say...I am L.M.F.A.O.!...almost 30 posts about size.Scott, you are absolutely correct,2" definitely makes a difference. Romeo, that is one BAD *** truck man.
Ltr.
Old May 9, 2008 | 08:28 AM
  #29
Scott06HEMI
Come on...what guy wouldn't want to add 2 inches regardless of how big it already is...
Old May 9, 2008 | 09:02 AM
  #30
getnarked100
HAHA! So true, so true.
